fibreglass
posted on 14/7/04 at 09:30 PM |
Wider bodywork
I will post some pictures tomorrow evening of the standard version of the Locost bodywork so you can all judge for yourselves, but in the mean
time.
The question i need answered is:
Is that 4" wider at the widest point only leaving the front section as per the book or: 4" added to overall dimensions. ie: 4" added
down centre of nosecone,bonnet and scuttle.
type 907
posted on 14/7/04 at 11:21 PM |
Hi FG
I can only speak for my own chassis
which is 4" added to all transverse members. All angles remain the same,
just everything 4" wider.
Look forward to seeing your pics.
Paul G
Too much is just enough
ned
posted on 15/7/04 at 08:46 AM |
Look at jim mcsorley's website. He does the drawings for the +4 chassis which you can download as pdf's. should give you any dimensions
you need.
Ned.
beware, I've got yellow skin
James
posted on 15/7/04 at 09:38 AM |
Fibreglass,
Most people insert 4" down the whole length of the car.
HTH,
James
posted on 16/7/04 at 10:41 AM |
Mine 4" wider everywhere, and 1" taller to keep the proportions closer to the original.
craig1410
posted on 16/7/04 at 05:18 PM |
Mine's 4" wider down the middle as per the McSorley 7+4 plans. My chassis is standard height but I'm using the slightly taller
bodywork from GTS albeit I'm going to have to cut it in half and widen it...
Craig.
