New Topic New Reply
Author: Subject: fuel gauge
martin62
posted on 20/4/11 at 09:09 PM Reply With Quote
fuel gauge
Can anyone enlighten me I am using a mk2 escort clocks and have a fuel tank sender from Kit Spares which is not reading properly.What can I do to fix this or do I have to get a separate guage.Thanks Aidan
posted on 20/4/11 at 09:23 PM Reply With Quote
You need to find a sensor which is matched in terms of resistance range to your dial. Randomly hoping that any old sensor will work with any old dial is going to end in tears, confusion and wasted time. Unless kit spares said it will work with your dials you need a different sensor...
karlak
posted on 20/4/11 at 10:23 PM Reply With Quote
I went to maplins and purchased a variable resistor, put it in line with the fuel gauge wire and adjusted it to show the correct levels.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
martin62
posted on 21/4/11 at 08:47 PM Reply With Quote
Hi Karlak thanks for the info will try and get one tomorrow.Would you know which one or have a part no.Thanks Aidan
[Edited on 21/4/11 by martin62]
New Topic New Reply
