Author: Subject: FS: Wilwoods, Pads & Discs, AVO's, Wishbones, Pedal Box, Etc.
posted on 24/4/11 at 04:25 PM Reply With Quote
Single-seater chassis is now at Windles, so I need to move-on the bits I won't be using in the re-build.
CALIPERS, PADS & DISCS
Wilwood Powerlite 4-Pots.
Wilwood Smart Pads.
108 pcd discs 240mm x 9mm in size.
All unused and retail at £325 from rally Design (including Del + VAT).
I'm looking for £195 and I'll include UK postage.
AVO ADJUSTABLE SHOCKS
Approx 16" when open.
Approx 11.5" when closed.
Spherical bearings.
Springs.
They are pretty light. In good used condition.
£100 including UK postage.
REAR-WISHBONES
From a single-seater. May be useful for someone building a special. In good used condition.
£40 including UK postage.
FIRE EXTINGUISHER
Lifeline Zero 2000 mechanical extinguisher. 2 litre cockpit & 2 litre engine. With 4 nozzles, pull handle (not pictured) and piping. In good used condition.
£75 including UK postage.
PEDAL BOX
Recently bought from James (seabass), but won't fit in the chassis I chose to use for the trike, so must go. Made by OBP - with bias-bar and natty 'reverse-style' accelerator pedal action! For hydraulic clutch. In good used condition.
Just looking for what I paid, so £100 + £10 postage if required.
PIPERCROSS AIR FILTER
New and unused. Approximately 44cm long x 15cm wide x 12.5cm deep. No backplate!
£45 including UK delivery.
MAGNETI MARRELLI ALTERNATOR
Ex-F1 24v alternator. Teeny-weeny and with military spec connector. Bought from Cosworth on a whim - I can't remember which F1 car it was fitted to. REMEMBER - IT'S 24v and probably only useful as a bit of geeky memorabilia!!!
£40 including UK delivery.
It's Evolution Baby!
posted on 24/4/11 at 04:26 PM Reply With Quote
Please list any interest on the thread before sending a U2U... that way everyone can see the state of play!
David_17
posted on 24/4/11 at 04:44 PM Reply With Quote
Hi. Do you know what hubs the willwoods are designed for?
Are they for a capri?
Ben_Copeland
posted on 24/4/11 at 04:55 PM Reply With Quote
240mm means there probably Sierra ones, but i'm sure scootz will confirm.
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 24/4/11 at 05:01 PM Reply With Quote
The discs will work with Ford Sierra derived hibs.
The Powerlites are radial-mounts.
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 24/4/11 at 05:29 PM Reply With Quote
Pm ab out to be sent re wilwoods Scotty
HowardB
posted on 24/4/11 at 05:31 PM Reply With Quote
happy easter,
does the filter just clip onto a back plate or similar?
would it be suitable for the TB's I bought from you?
thanks
Howard
posted on 24/4/11 at 05:42 PM Reply With Quote
Originally posted by HowardB
happy easter,
thanks
It would Howard... you'd need to either buy a blank backing plate, or cut your own.
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 24/4/11 at 05:43 PM Reply With Quote
Willwoods not suitable for me so i'm out.
Roll up guys these are a bargain and you wont find a better guy to deal with.
posted on 24/4/11 at 06:03 PM Reply With Quote
Cheers Craig.... where do you want your bribe sent to?
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 24/4/11 at 06:10 PM Reply With Quote
Usual account mate . You know the one lol
Davg
posted on 24/4/11 at 06:31 PM Reply With Quote
Scootz, i'll take the brakes also the filter if Howard is out! cheers D. u2u to follow
posted on 24/4/11 at 07:05 PM Reply With Quote
BRAKE PACKAGE, FILTER & FIRE EXTINGUISHER SOLD
Thanks.
westy turbo
posted on 25/4/11 at 08:45 AM Reply With Quote
pmed for lifeline
Hugh_
posted on 26/4/11 at 06:58 AM Reply With Quote
2nd dibs on the brakes please.
posted on 2/5/11 at 10:47 AM Reply With Quote
Any offers on what's left before they go on eBay?
AVO Shocks
Rear Wishbones
Pedal Box
Alternator
bugeye29
posted on 2/5/11 at 12:56 PM Reply With Quote
I am interested in the pedal box, I have sent you a private message requesting some information.
Thanks,
Wayne
iceman26
posted on 2/5/11 at 01:06 PM Reply With Quote
what uprights do you use with the rear wish bones and do you still have them
posted on 2/5/11 at 02:41 PM Reply With Quote
Hi Iceman
The uprights have been sold - you'd have to have a set fabricated to suit (I could put you in touch with the man who made them).
