couch22k
posted on 28/4/11 at 06:19 PM |
Pinto Timing HELP
Right, after posting this post I have now had a new pito engine
built with a spare 205 block I had.
Got it all back in today and when i came to time it up I got a little confused. It started up not to bad and sounds spot on, but when I put the timing
light on I got a little confused.
On the pulley there are the standerd 4/5 marks for TDC 4/8/12 degree but about 35/40mm to the right of the marks(clockwise) there is a single mark
that is what is seems to be timed to.
Im not sure if this was there before or if its been added. As I have very little mechanical knowledge I dont want to start moving the dizzy to
much.
Tried getting hold of the builder but it was to late and hes not back in till Tue and I was hoping to run it in a little this weekend.
Any help would be appreciated
jacko
posted on 28/4/11 at 06:26 PM |
If its like mine i put another mark at 36% its so when i use a strobe lamp i can set the timing up.
What i do is rev the engine to 3000rpm and the dizzy should line up with this mark
Jacko
couch22k
posted on 28/4/11 at 06:30 PM |
Jacko
Cheers Jacko
So the builder put this mark on, will it be TDC??
If it sounds sweet enough do you think it will be ok to put a few miles on it this weekend.
marcjagman
posted on 28/4/11 at 06:33 PM |
If it starts, runs and ticks over okay then it probably is set correctly.
jacko
posted on 28/4/11 at 06:35 PM |
Are you using a strobe light to set it up ? if so i would set it at 12% for a std ford camshaft
I don't know if it will be ok to drive it with out seeing/ working on the engine Sorry
If its week on mixture etc it will damage your nice new engine
Sorry Jacko
couch22k
posted on 28/4/11 at 06:39 PM |
Sorry Jacko
Yeah using a Snap on Strobe I borrowed. Think It might be safer leaving it till Tue after the money ive spent
snapper
posted on 28/4/11 at 06:54 PM |
The builder has put marks for all in timing at 3,600 rpm.
Timing for a Pinto should be someware near 10 degs at idle rising at around 1300rpm to a maximum 36 or 38 degrees at 3,600 rpm with the vac advance
removed.
The builder may have cut a new TDC mark and timed from there.
I eat to survive
I drink to forget
couch22k
posted on 4/5/11 at 09:16 AM |
All Sorted Now
Thanks for all your advice. 200 miles to run it in then oil and filter change quick session on rolling road to sort the carbs out and i'll be
ready for Newark
