Author: Subject: Pinto inlet manifold help
posted on 16/7/04 at 04:57 PM Reply With Quote
Hi guys,
Can anyone help me out with the pipe connections on my Pinto inlet manifold???
Which are coolant, vacuum etc....
speedthing
posted on 16/7/04 at 09:50 PM Reply With Quote
hi nick
from left to right
coolant inlet
crank case vent
vacuum for servo
hope this helps
posted on 16/7/04 at 10:22 PM Reply With Quote
Thanks Speedthing - I can get on with plumbing it all in now!
Presumably I can connect the crankcase breather on the block directly to the manifold?
Or does it need some kind of oil seperator?
Cheers again
Nick
speedthing
posted on 16/7/04 at 10:46 PM Reply With Quote
nick
pipe connects to the p.c.v valve and then pushes into the breather on the block
[Edited on 16/7/04 by speedthing]
