Author: Subject: Fitting Windscreen
digiman
posted on 7/5/11 at 08:31 AM Reply With Quote
Fitting Windscreen
Hello All,
Just checking for advice. I've got a Formula27 with a carbon fibre scuttle/dash. I'm fitting a caterham windscreen and thinking of bolting it on through the carbon fibre into an aluminium backplate. I reckon I need some thing between the carbon fibre and the metal parts, so plan to use neoprene (old wetsuit) just to avoid any excess stress. Any comments?
So the sandwich would be:
Nut, Washer, Aluminium plate, neoprene, Carbon Fibre, Neoprene(?), Aluminium Stanchion, bolthead.
Many Thanks
Martin
Greenie
posted on 7/5/11 at 11:33 AM Reply With Quote
Sounds like you have answered your own question...... sounds fine good luck!
mangogrooveworkshop
posted on 7/5/11 at 12:56 PM Reply With Quote
Pu the Ali inside and that will be fine
se7en
posted on 7/5/11 at 02:09 PM Reply With Quote
Did you not read his post?
digiman
posted on 7/5/11 at 04:09 PM Reply With Quote
All done and dusted. Makes one hell of a difference. Now for the wipers and washer..
