Author: Subject: Manifold Length
greggors84
posted on 17/7/04 at 01:24 PM Reply With Quote
Manifold Length
Ive got the problem of my carbs being the same height as the top chassis rail. I phoned burtons and they said they do a manifold that raises the cabs up. When i got it throught the post, its the same as the one i have. Phoned them up and they said they dont do one that raises it up????
Anyways, they said they do a really thin one, i can exchange it for this, but i wondered will this mess up the carb settings.
The carbs have been set up with the engine when i bought it, will changing the manifold length significantly mess it up. I am planning on getting the carbs set up on a rolling road properly anyway. But i would like it to drive first, i dont mind if its a bit out.
Chris
The Magnificent 7!
Viper
posted on 17/7/04 at 01:47 PM Reply With Quote
Shouldn't upset the carbs, different length manifolds will affect torque though, if memory serves, the longer the manifold the more torque you will have and vice versa, not a problem in a car that weighs so little
speedthing
posted on 17/7/04 at 03:52 PM Reply With Quote
hi greggors
i have an inlet manifold pinto to twin fortys
that will lift the carbs up quite steeply
yours for £45 i can send a picy if you like
greggors84
posted on 18/7/04 at 12:57 AM Reply With Quote
Speedthing You have U2U
Chris
The Magnificent 7!
speedthing
posted on 18/7/04 at 06:30 PM Reply With Quote
hi chris
my u2u seams to be up the stick
have sent you email
cheers alun
