Author: Subject: Blade 954 cooling system
ZEN
posted on 7/5/11 at 09:43 PM Reply With Quote
Hi!
I'm in the process of fabricating a new cooling system for my build. The engine is a blade 954 RR and I'm fitting i to a MK2 VW polo 1.0 radiator.
I'm not relay sure where to fit the "air bleed hose", as the polo rad has only the upper, lower and siphon hose connections.
Any suggestions?
[/URL ]Uploaded with [URL=http://imageshack.us]ImageShack.us
[Edited on 7/5/11 by ZEN]
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
johny p
posted on 7/5/11 at 09:50 PM Reply With Quote
have you ever thoght of removing the mechanical water pump and fitting an electric pump.. thats what i have on mine.. frees up some bhp!!!!!
joni
posted on 8/5/11 at 12:56 AM Reply With Quote
radtech
go for a radtech rad so much better than a polo rad runs much cooler
ZEN
posted on 8/5/11 at 09:38 AM Reply With Quote
Maybe in the future.
No radtech distributors in Croatia as far as I know.
mad-butcher
posted on 8/5/11 at 09:58 AM Reply With Quote
complicated to explain but on mine, large pipe on blade thermostat housing to rad top hose, the small hose on thermostat housing goes into a T piece one pipe on the T goes to the small pipe on the polo rad the other pipe on the T goes to the header tank, large pipe on header tank T's into bottom hose, I'm using a volvo header tank,
I've tried a search for the diagrams on here but I've had no luck.
tony
ZEN
posted on 8/5/11 at 02:02 PM Reply With Quote
If I understood correctly it would be something like this?
Uploaded with ImageShack.us
BTW, my polo rad has no filler cap. I should fill the rad with water through the header tank.
What about yours?
[Edited on 8/5/11 by ZEN]
mad-butcher
posted on 8/5/11 at 06:08 PM Reply With Quote
OK I think I should have said expansion tank not header tank, I beleive a rover 25 is a popular one , yes your diagram is basically correct except the tank needs to be above the engine, ie the highest point in the system, a lot of people mount it on the scuttle
tony
ZEN
posted on 9/5/11 at 10:24 PM Reply With Quote
I am aware that the expansion tank should be the highest point in the system.
Thanks for the answer!
