Author: Subject: I need to convert psi to kg?
hootsno1
posted on 8/5/11 at 12:36 PM Reply With Quote
Hi all
I want to try out my powder coating kit it says i need 1kg of air to project the powder what i need to now is what that is in psi/lbs please.
[Edited on 8/5/11 by hootsno1]
If a little hammer won't fix it get a bigger hammer
bigrich
posted on 8/5/11 at 12:44 PM Reply With Quote
1 Kg/cm is 0.98 bar or 14.22psi after a quick google
richmars
posted on 8/5/11 at 12:46 PM Reply With Quote
Depends what the Kg is over, cm^2, m^2. Without that it's a guess.
designer
posted on 8/5/11 at 02:41 PM Reply With Quote
Download this, it's all you will ever need.
http://joshmadison.com/convert-for-windows/
Liam
posted on 8/5/11 at 02:56 PM Reply With Quote
As awesome as Convert.exe is, you still can't convert a mass into a pressure! Need more info.
designer
posted on 8/5/11 at 03:29 PM Reply With Quote
Isn't it a straight PSI/BAR conversion?
richmars
posted on 8/5/11 at 04:26 PM Reply With Quote
No. Kg is mass, PSI is pressure (force per area). The assumption made above is that the required unit is something like Kg/cm^2. But without knowing what the area unit is, cm^2, m^2 etc, it's not possible to convert it.
hootsno1
posted on 8/5/11 at 06:48 PM Reply With Quote
My home powder coating kit instruction says it needs a working air pressure range of0.5kg to 1.2 kg 1 kg is recommended that's all I have to go by?
Ninehigh
posted on 8/5/11 at 08:09 PM Reply With Quote
I'd guess it's kg/cm2 as m2 is 1000x larger, thus the pressure would be 1000x less?
So you're talking 14.22 psi or 0.0014 (almost a vacuum?)
