Yorkie
posted on 11/5/11 at 12:52 PM |
Centre Mirror and Aeroscreen
I'm having difficulty deciding how to mount the centre mirror.
My two options are: Mount the mirror to the scuttle and pass the stem through a hole in the aeroscreen or mount the mirror directly to the
aeroscreen.
Not sure if the aeroscreen is strong enough when bolted in place.
How have you mounted yours?
40inches
posted on 11/5/11 at 12:57 PM |
I used the first option and used a grommet to seal around the mirror stem
afj
posted on 11/5/11 at 01:02 PM |
option one here
eerrrrrrrrrrrrrrrr
Humbug
posted on 11/5/11 at 01:03 PM |
Th thread here shows a pic of how I mounted mine: solid mounted to the scuttle
though the screen with a spacer, so the screen is sandwiched between the top and the spacer. It made it very stable and also helped reduce flex of the
aeroscreen.
big_wasa
posted on 11/5/11 at 01:35 PM |
The first one.
couch22k
posted on 11/5/11 at 02:48 PM |
Option 1 on the scuttle mine.
adithorp
posted on 11/5/11 at 03:47 PM |
I spoke to someone at Stoneleigh with option 2. I t was being altered to Op1 as Op2 vibrated so much the mirror was useless.
http://jpsc.org.uk/forum/
Yorkie
posted on 11/5/11 at 03:50 PM |
Thanks guys.
Option 1 it is then.
![](/images//smilies/smile.gif)
