<<  1    2  >>
Author: Subject: Cut down car 'box for reverse and Hi/Lo ratios
60 Plymouth
posted on 11/5/11 at 02:34 PM Reply With Quote
Hi again guys,
Odd one this but it's not the first time it has been discussed on this board. I'm looking at building a reverse trike BEC. Trouble with BECs is the reverse gear. The electric reverse is about the best low cost option, but where I live I have to back up an access road, then down into my driveway (or back up the driveway and down the access road). An electric reverse may be ok but I'm not sure. Getting out and pushing is probably the best option but it'd be nice to at least come up with somthing more engineery. So I thought about using a car gearbox with most of the gears removed (two forward one reverse?).
Searching around here shows a few other people have thought of it, mostly using a transaxle at the rear, but Ned mentioned an Escort gearbox (Type 9?) being used in the trans tunnel. I'd be willing to accept the weight of a type 9 (22kg for the four speed?), not so sure about the transmission losses. I could get the advantage of having a hi and lo ratio for town/country driving.
My concern is that by the time the engine torque has gone through the bike's own primary and gearbox, I'd be looking at over 330ft lbs of torque (assumed a pan euro engine for now). Am I right in thinking this will do nasty things to a Type 9? Although I could live with 22kg weight penalty of a Type 9 I'm not so keen on 50kg for somthing a Rover V8 would need.
Any other info on BECs that use a cut down car gearbox for reverse? What did ya use and how heavy was it?
Thanks for your help guys,
Conor
blakep82
posted on 11/5/11 at 02:56 PM Reply With Quote
just a mention, there is no 4 speed type 9. type 9s are ALL 5 speed, before you start scouring the internet for something you won't find.
but why remove half the gears? why not just leave them in? i don't think they'd do any harm in there would they?
would you need another clutch on the car box? or will both work quite happily just off the bikes clutch?
interesting idea though!
[Edited on 11/5/11 by blakep82]
________________________
60 Plymouth
posted on 11/5/11 at 03:05 PM Reply With Quote
I thought the earlier type 9s were four speeds and thats why the overdrive gear is housed in the tailshaft in the five speeds? Am I thinking of another box?
One of the reasons I want to remove the additional gears is to reduce friction, since all the gears are constantly meshing there must be a loss there, it'd also knock a few pounds off but that's less of an issue. How much this would save I don't know.
I'd like to use 4 as my top gear - since it runs straight through it might have less power loss than the other gears. Is that reasonable?
60 Plymouth
posted on 11/5/11 at 03:12 PM Reply With Quote
I'd only use the bike clutch. The car gearbox would be treated a lot like the hi/low ratios in a land rover, or a two speed rear axle like Ford Ts used, selected in anticipation of the type of driving you do.
Having said that, it should still be possible to shift on the fly. Depressing the bike clutch would unhook the engine from the bike trans. Hopfully the synchros in the car gearbox will be enough to match the two gearboxes together to allow the car-shift to be made. It won't exactly be a fast acting gear shift, but a hell of a lot quicker than changing the rear end ratio!
blakep82
posted on 11/5/11 at 03:14 PM Reply With Quote
the type 9 fords first 5 speed box, based on i think the type E, which is a 4 speed box
but type 9 is only the 5 speed.
makes sense. thought it might have been handy, if using the type 9, to have the extra overdrive for better MPG, but otherwise makes sense. sounds interesting anyways, and something i know nothing about lol. i don't like taking gearboxes apart. they never work after i've had a go at them...
stevebubs
Early Genesis BECs used (I think) a Rover 200 Gearbox in a similar fashion...
[Edited on 11/5/11 by stevebubs]
60 Plymouth
posted on 11/5/11 at 03:25 PM Reply With Quote
It's always encouraging to know I'm not the only one foolish enough to think of stuff like this.
That makes sense about the Ford boxes. Overdrive I'm not fussed about at all - I plan to use a Goldwing final drive/brakes on the back wheel and that's already got a tall 2.75 ratio.
A little searching seems to suggest that Type Es ain't cheap - shame. I wonder if there are any around with knackered first gears going cheap . . . .
Any other tough-as-nails, lightish RWD four speeds about? Heck even a three speed if the top two gears are reasonable. . .
blakep82
posted on 11/5/11 at 03:27 PM Reply With Quote
have a look here and see if anything suits
http://www.burtonpower.com/tuning-guides.html
TQ_uk
posted on 11/5/11 at 03:59 PM Reply With Quote
I seem to recall theres a guy in NZ running a Hayabusa engine in a Toyota Starlet retaining the car gearbox in addition.
He'd got a simple setup where the original clutch pedal also pushed down on a bike clutch lever to disengage both clutches on gear changes.
Will see if I can find a link....
Linky
[Edited on 11/5/11 by TQ_uk]
Better link to original forum
Doctor Derek Doctors
posted on 11/5/11 at 04:43 PM Reply With Quote
Seems like a decent idea, but why use an old (and increasingly rare) Ford Gearbox if you're not using a Ford Engine? There are probaly millions of newer and lighter gearbox's sitting in scrapyards around the country.
Anything that doesn't have a built in Diff will do? Something from a BMW? MX5?
Or you could even use an Audi Transaxle from a FWD Audi and then you would have the diff included as well. I bet it would quite easily go were the diff sits in a '7'
mark chandler
posted on 11/5/11 at 04:48 PM Reply With Quote
Its the toque in the gears that would kill the box, you could use a weedy little box and leave in 4th (if straight through) to good effect, run it in reverse and you have 3 overdrive cogs.
Suzuki sj410 have little boxes, once you hack off the bell housing, first motion shaft towards the axle and away you go.
zilspeed
posted on 11/5/11 at 05:07 PM Reply With Quote
Pic from the link to the Starlet further up the thread.
I got Andy to waterjet me a drive plate to suit the spline on a ford box and standard four bolt drivshaft pattern to do just this thing.
If you read the thread above, the builder has nothing but praise for this reverse setup.
To the right of the slave is the front driveshaft this bolts to the bike sprocket which we turned into a 4 bolt flange just like a diff pinion. The front driveshaft takes a very short and very angular route to a standard toyota k40 gearbox with the bell housing cut off and mounted further back in the car, the driveshaft has a starlet clutch hub inside it to drive the input shaft, it also has a couple of bearings so that the shaft can slide on the snout the clutch release bearing normally does, this allows for any movement between the engine and the k40 box. We run this gearbox in 4th gear all the time except when we use it for reverse, 4th is 1:1 ratio so its just like a straight through driveshaft.
From here its just a shortend driveshaft to the nissan diff.
You can buy a quaife reverse box but i couldnt afford one and had an excess of starlet boxes so thought we'd give this a try first, so far its without a doubt proven itself which is pretty impressive when you consider its getting fed output shaft torque after the busa g/box and when its in 6th its pulling engine revs!!!!
Here's the closeup.
[Edited on 11/5/11 by zilspeed]
60 Plymouth
posted on 11/5/11 at 05:13 PM Reply With Quote
Hi Guys,
Thanks for the replies. I picked the Ford box for its weight (22kg) - to register the reverse trike as a motorcycle I have to keep it under 450kg unladen. Alternative boxes are certainly an option.
Finding small, lightweight boxes designed for a rear wheel drive seems to be difficult though, most of the modern front engine rear wheel drive cars seem to be a lot heavier (I'd be delighted to be corrected on this ) , and the Ford boxes are fairly well catered for by kit car guys and retro Ford enthusiasts, so they have been what I have looked at.
I am aware of the Suzuki gearboxes, I have looked at the engines too, they are very light weight but I have a limited choice of rear end ratios (basically 2.75 if I use a Honda GL1800 final drive, any other final drive and mounting wheels, designing swingarms, fitting brakes all becomes complicated). Ihaven't considered the MX5 gearbox though.
That tall rear end ratio is one of the reasons I was looking at an 'under drive' type option. Does running the box back to front have any structural advantages to running it the right way round? I guess there's usually more torque at the propshaft than there is at the clutch.
If I was to get a box with an overdrive top ratio, and run that backwards (to get the under-drive type ratio) would that have similar strength advantages? Not as strong as running it straight through presumeably.
60 Plymouth
posted on 11/5/11 at 05:22 PM Reply With Quote
That Starlet's a fantastic thread - couldn't get the pictures up whilst I was at work.
Another advantage of that set up looks to be the ease of swapping motors out, so you could sling any bike engine straight into it with very little modification and not even have to perfectly align the propshaft.
franky
posted on 11/5/11 at 05:46 PM Reply With Quote
I'm pretty sure the type 9 is a damn lot heavier than 22kg too.
60 Plymouth
posted on 11/5/11 at 05:48 PM Reply With Quote
I think I was referring to the Type E. Type 9s are apparently at about 34kg, what I thought was the 4 speed version is 22kg. I'll try and find the link for it.
Suzuki Samurai trans is apparently 27kg.
Liam
posted on 11/5/11 at 07:45 PM Reply With Quote
I'm sure it would work fine as in that Starlet. I personally prefer the elegance of Doctor Derek Doctors' idea of using a renault/audi/subaru transaxle though. Diff and box in one unit will save overall weight, not require a large tunnel, and avoid needing two propshafts. Win!
posted on 11/5/11 at 08:10 PM Reply With Quote
And people didn't believe that I work in F1.............
60 Plymouth
posted on 11/5/11 at 08:45 PM Reply With Quote
I fully agree that a transaxle would be a much better option, allowing fully independent rear suspension and better weight distribution. Using an Alpha box you could stick inboard disk brakes at the back and reduce unsprung weight even further.
The only downside is that it's not as applicable a single wheel at the back.
I did consider using a belt drive from a transaxle (either two belts or a locked diff but it either widens the car, lengthens the car, and definately makes it more expensive.
zilspeed
posted on 11/5/11 at 08:53 PM Reply With Quote
It's a heavy lump of a thing is a Passat box.
I remember a long time ago a bloke called Neil Gammie used to race a Westfield up here.
It had a crossflow driving a Hewland MK9 mounted at the back like normal.
This would have had the prop running at full speed.
I understand that the ease of ratio changing along with weight distribution were the main attractions.
owelly
posted on 11/5/11 at 09:05 PM Reply With Quote
I've been working on a dumper and it has a reversing gearbox sandwiched between the bellhousing and main gearbox. Something similer would suit your needs if you have the time to do a bit of twebbing for info. Basically, it's a box with a reverse shaft mounted to one side. It uses a dog gear to drive the dumper forward but when the reverse lever is tugged, the dog disengages the mainshaft and the dog gear engages the reverse shaft wich then drives the other end of the main shaft but in reverse. If that makes any sense?? I fairly small unit but very tough.
http://www.ppcmag.co.uk
60 Plymouth
posted on 12/5/11 at 07:35 AM Reply With Quote
Hi Owelly,
That sounds interesting, mind me asking what the make of dumper is? How heavy is it (the dumper)?
TQ_uk
posted on 12/5/11 at 08:26 AM Reply With Quote
Isn't that essentially the same method as the available reverse boxes (MNR/Quaife/Westfield etc)?
60 Plymouth
posted on 12/5/11 at 06:44 PM Reply With Quote
Basically the same yeah, but cheaper, and with a possible overdrive. Also, if/when it breaks,haul it out and sling another in for cheap.
Downside is weight. If I wasn't so tight fisted, I'd probably go for a Quaife style reversing box.
TQ_uk
posted on 13/5/11 at 10:23 AM Reply With Quote
Don't worry, I've often thought along similar lines, like fitting a bike engine to a VW (beetle) transaxle in a lightweight buggy for example.
Here's a post with some views on electric vs mechanical
<<  1    2  >>
