Author: Subject: FS: Good Spec C20XE Red-Top Engine
posted on 23/5/11 at 08:24 PM Reply With Quote
Pre-94 model, so makes IVA a whole lot easier!
New Timing-Belt.
New Tensioners.
New Waterpump.
New Oil Pump.
New Oil Filter.
New Sump Gasket.
New Rocker Gasket.
New Stainless Rocker Fasteners.
New Lightweight Ali Pulley.
Freshly powder-coated cam cover and spark-plug cover.
Cam-cover has had the 'lip' machined off.
Good clean cosmetic condition.
QED420 Cams.
Kent Vernier Pulleys.
Baffled and shortened ali sump.
Dizzy Blanked.
Has porous-head 'fix' and cam-cover breather mod.
Alcon 5.5" twin-plate clutch.
Custom lightweight ali flywheel.
Made 210bhp on dyno when fitted with Weber 45's.
I can give you a belt-train cover if you would prefer to run the engine with one. You would then need to pick up a standard cam-cover from eBay (not expensive). I can also give you a starter motor and a pair of engine mounts..
Looking for £950 (the clutch and flywheel cost more than that!).
I would consider an 'interesting' swap / PX.
Pallet delivery would be an extra £50, or I could take to Newark.
[Edited on 24/5/11 by scootz]
It's Evolution Baby!
posted on 24/5/11 at 10:45 AM Reply With Quote
Updated with pics!
posted on 24/5/11 at 01:54 PM Reply With Quote
Provisionally sold. Will know for sure on or around 10th June.
cd.thomson
posted on 24/5/11 at 04:15 PM Reply With Quote
ooo shiney and (relatively) cheap! Good luck with the sale
Craig
mcerd1
posted on 24/5/11 at 06:06 PM Reply With Quote
thats cheap
have I missed a thread or are you keeping its replacement a secret ?
[Edited on 24/5/2011 by mcerd1]
posted on 24/5/11 at 06:12 PM Reply With Quote
My garage is empty for the first time since it was built Robert!
All systems are now go for the trike!
mcerd1
posted on 24/5/11 at 06:36 PM Reply With Quote
I don't beleve you - I'll have to come round and inspect it
posted on 24/5/11 at 06:37 PM Reply With Quote
Feel free... I'm in most of the time and there's a kettle up there!
