Author: Subject: Unfinished Tiger Avon Project
Martin1989
posted on 24/5/11 at 01:00 PM Reply With Quote
Hi all,
Due to me not having enough time to finish this project unfortunately I'm having to sell it. Below is a list of parts that are included and there are also some pictures. Going to put it on here before it goes on Ebay or might even brake it for parts. Any questions just U2U.
I'm looking for around £3300 for everything (owes me a lot more then that)
- Tiger Avon Chassis (all ali panelling done apart from 2 sheets which were left off so brake pipes can go in)
- Tiger Avon Body work (needs some repair work)
- 1998 Silvertop Zetec Engine (Out of a 1998 Mondeo which had covered 60,000 miles)
- Type 9 gear box
- 3:92 differential out of a Sierra
- Team Dynamics 1.2 Pro Race black 15” wheels
- Toyo R888’s all round (Partly worn)
- Drive shafts
- Prop shaft
- Aluminium fuel tank
- Aluminium oil catch tank
- Front wishbones and rear uprights
- Nearly new GAZ shocks
- Sparco 4 point harnesses
- Sparco steering wheel
- Sierra steering column
- Steering rack and all the necessary components
- New steering gaiters and track rod ends
- New brake master cylinder
- Brand new Wilwood 4 pot Powerlite brake callipers
- Reconditioned rear Sierra brake callipers
- 25ft of new brake copper piping
- Full 4-1 exhaust system with silencer
- Lightened flywheel and clutch
- Bogg Bros manifold to fit a Zetec and take 45mm throttle bodies
- ZXR 45mm throttle bodies
- Injectors
- Throttle linkage
- Throttle position sensor
- Fuel rail
- 4 individual air filters and a Pipercross air filter
- Chrome lights, all brake lights and indicators that are required
- Tiger seats
- Full dash with all the necessary dials and switches
- All interior upholstery and carpets
- Low pressure fuel pump
- ERA Sump
- New mud guards and throttle cable cover
- Few other bits and pieces I have probably forgotten about
shindha
posted on 24/5/11 at 03:12 PM Reply With Quote
U2U
Hello Martin,
I have just sent you a u2u could you please confirm as I am not sure if it processed correctly.
regards Shindha
Martin1989
posted on 24/5/11 at 03:24 PM Reply With Quote
U2U received and replied.
neilp1
posted on 24/5/11 at 07:29 PM Reply With Quote
u2u sent
Martin1989
posted on 27/5/11 at 01:14 PM Reply With Quote
Tiger Avon 2.0 Zetec - Unfinished project | eBay UK
Now on Ebay.
montythemole
posted on 27/5/11 at 03:10 PM Reply With Quote
Mine sold to a chap in Germany, came over and took away on trailer. Had quite a lot of interest from over the channel. Presume they have a smaller kit car industry so if you want a cheap track day car an unfinished UK Tiger etc is a worth the drive.
1985 Dutton Phaeton Series 3 1300GT
