Author: Subject: Where can I get ?
vintagebuilder
posted on 21/7/04 at 08:52 AM Reply With Quote
Where can I get ?
Morning ,
Could anyone tell me where I could get a set of yellow coloured plug leads for a Pinto ( no p**s taking answers please). Also why are some plug leads 7mm dia and others 8mm. Does it make any difference.
Finally, has anyone had any experience with the Lolocost radiator fan, it seems amazing value at £13.
Regards
Terrapin_racing
posted on 21/7/04 at 09:27 AM Reply With Quote
These guys - good service
http://www.vehicle-wiring-products.co.uk/VWPweb2000/HTleads/HTleads.html
and HT lead size
http://www.magnecor.com/magnecor1/7mm8mm.htm
Chris Leonard
posted on 21/7/04 at 11:49 AM Reply With Quote
i have used the lolocost fan - I works OK - I got stuck in traffic for 15 mins hardly moving and it kept the temp at a resonable level
stephen_gusterson
posted on 21/7/04 at 12:18 PM Reply With Quote
I have used one - but the cars not on the road yet. Works OK cooling the car on a 30 min tickeover.
Its a Honda part.
Only reservation is that its not ideal for the fan profile mounting it on the front of the rad - its intended to go behind, so the motor direction hast to be reversed polarity.
atb
steve
vintagebuilder
posted on 21/7/04 at 01:18 PM Reply With Quote
Thanks for the information.
Steve, if I mount it in front of the rad.ie furthest side from engine do you have to reverse the fan blades so it becomes a "pusher" rather than a "puller".
