Author: Subject: Spring compressor
efiniste
posted on 7/6/11 at 07:54 PM Reply With Quote
Spring compressor
Any recommendations on which type to get? There's a couple at Machine Mart for £30 and £45 but I've never used one before so could do with a couple of pointers.
It's for changing the springs on my RX-7, maybe a couple of times until I'm happy with the spring rates. It certainly won't be used everyday.
Thanks,
mookaloid
posted on 7/6/11 at 08:00 PM Reply With Quote
I like this kind myself PRO QUALITY HEAVY DUTY COIL SPRING COMPRESSOR SET - NEW | eBay UK
pekwah1
posted on 7/6/11 at 08:02 PM Reply With Quote
what he said, used the same type with good results!
mad-butcher
posted on 7/6/11 at 08:28 PM Reply With Quote
I use the same type myself but a lot more expensive. You'll Probably be OK with the Ebay ones, But at that price I'd be very carefull using them.
tony
tomgregory2000
posted on 7/6/11 at 08:29 PM Reply With Quote
Used same sort of thing and they work and i have all my fingers
mookaloid
posted on 7/6/11 at 08:47 PM Reply With Quote
tony
the thing with those - although they are cheap they are very meaty - much better than the single prong ones which look very feeble like these which I wouldn't be happy with Car Coil Spring Compressor tool for uprated shocks pair | eBay UK
ashg
posted on 7/6/11 at 09:13 PM Reply With Quote
i have got these laser ones from halfords. not that cheap but they are spot on
http://www.google.co.uk/products/catalog?hl=en&xhr=t&q=laser+spring+compressor&cp=10&bav=on.2,or.r_gc.r_pw.&biw=1920&bih=1061& amp;um=1&ie=UTF-8&tbm=shop&cid=13832698595246966772&sa=X&ei=1ZPuTaLlLsWp8QOd1dnKBw&sqi=2&ved=0CFUQ8wIwBA
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
LoMoss
posted on 7/6/11 at 09:37 PM Reply With Quote
A spring compressor failed on me and put me in the hospital. It slid round the pug 405 string, it fired one through a plaster board wall the other bounced off a stone wall and hit me in the face. smashed my eyebrow, nose and top lip. lukily it was length ways. An end on hit would have gone through my eye and killed me. Would recommend putting a ratchet strap around too, or take it to a mates garage and give him the money instead.
HTH
Hall
Chippy
posted on 7/6/11 at 10:34 PM Reply With Quote
Second these, good quality piece of kit, for a very reasonable price. Cheers Ray
mookaloid
posted on 7/6/11 at 11:00 PM Reply With Quote
HTH
Hall
ouch - sounds nasty. what style of compressor was it that failed?
posted on 8/6/11 at 05:48 AM Reply With Quote
They don't slide round the spring if you position them correctly and tighten them up evenly
Sykes-Pickavant/Draper type
[Edited on 8/6/11 by britishtrident]
efiniste
posted on 8/6/11 at 08:30 AM Reply With Quote
Thanks for the pointers and warnings fellas. I'll order a set of the (first) eBay ones and give them a go.
LoMoss
posted on 8/6/11 at 07:41 PM Reply With Quote
^^^^^^^^^^ Like those! Had used them before, never again. Get the big hooky ones.
