Author: Subject: Megajolt Fireblade Carbs ITG + Zetec Manifold
Billbro
posted on 12/6/11 at 01:29 PM Reply With Quote
Megajolt V3.2.1 ECU programmed with a working map for a Zetec 1800/2000cc.
EDIS 4 unit and plug. Plug has a broken plastic connector pin but works well.
Fireblade carbs with rubbers, fuel pipe, trumpets, tick over adjuster and throttle position sensor. Jetted for an 1800/2000cc Zetec.
ITG air filter with spacer and backing plate (home made). The filter has a bulge on the front but could be fastened to the frame from behind.
Steel Zetec 1800/2000cc inlet manifold to suit carbs.
All used but working and recently removed from my car.
Picture in my archives, email for more pictures. bill@brooksb.freeserve.co.uk.
Selling as a lot. £290 + post.
David_17
posted on 16/6/11 at 06:51 PM Reply With Quote
u2u sent
