birdii
posted on 17/6/11 at 12:01 PM |
Handbrake levers mounted on the side of the transmission tunnel - pics?
Does anybody have some photos of handbrake levers mounted on the side of the transmission tunnel please?
Been searching the forum all lunch break and still short of inspiration!
I have mounted mine on top in the center of the tunnel but I'm not keen, it's under my elbow when changing gear.
Thanks in advance!
mangogrooveworkshop
posted on 17/6/11 at 02:11 PM |
I sink them into the tops of the tunnels so when they are not in use it sits flat away from your elbow.
Some heavy chanell rubber on the top surface and it's good to go
HAL 1
posted on 17/6/11 at 03:54 PM |
I know MGBs and Midgets use side mounted levers so googling images might show something for you.
Liam
posted on 17/6/11 at 04:46 PM |
I quite like where they go on a Dax Rush - sort of hidden out of the way under the steering column...
tul214
posted on 17/6/11 at 05:10 PM |
Have a look at page 8 of this thread
http://www.pistonheads.com/gassing/topic.asp?h=0&f=30&t=832304&mid=0&i=140&nmt=Mac%231+Motorsport+Worx+Build&mid=0
[Edited on 17/6/11 by tul214]
1.6 Raw Super6 sold
JAG
posted on 17/6/11 at 06:33 PM |
How about this?
Justin
matt_gsxr
posted on 17/6/11 at 06:43 PM |
if you search (google images section) for "sylva handbrake" you get some hits.
The striker and phoenix did it this way, maybe J15 too. Very good for adjust-ability. But difficult to make it look neatly in my opinion.
On my Phoenix I put it into the tunnel, although its a real bitch to adjust once the prop is in.
Matt
(edited because for some reason I put that I had a Striker!)
[Edited on 17/6/11 by matt_gsxr]
birdii
posted on 18/6/11 at 08:46 AM |
Thanks, given me something to think about! I will have a good look around at Newark today too.
cheers
Dan
Surrey Dave
posted on 6/7/11 at 01:21 PM |
MG Midget
Handbrake mounted on the top is absolute pants ,will be in the way all the time and look sh1te!
[img][/img]
[Edited on 6/7/11 by Surrey Dave]
RickRick
posted on 6/7/11 at 02:11 PM |
between the brains of locosters we must be able to design a electric handbrake that is cheap to make, and there's enough people on here with
lathes and mill/water jets, there could even be a kit forsale in the shop!!!
i'm going to put one on my car, it's just a case of when, something along the lines of a scissor link with the cables at one end and a
screw thread at the other, motor to drive thread. having it electric seems like the best way to stop naughty people taking off the hb and pushing
your car into a different carpark at work or onto a trailer!!
Marcus
posted on 7/7/11 at 07:18 PM |
I'll try to find a better pic, but here's mine:
[img]
Dash 06
[/img]
Uses an MR2 lever and first cable.
Marcus
Because kits are for girls!!
