Author: Subject: I have a 2.0 sohc engine in my kit car with the standard webber carb on, would it make much difference in power if i fitted a se
rich201283
posted on 23/7/04 at 12:01 PM Reply With Quote
I have a 2.0 sohc engine in my kit car with the standard webber carb on, would it make much difference in power if i fitted a set of dcoe's carbs?
phelpsa
posted on 23/7/04 at 12:05 PM Reply With Quote
I nominate this post as the post with the longest subject ever on this forum.
I can't answer your question though.
Adam
chick
posted on 23/7/04 at 12:33 PM Reply With Quote
I would really recommend the book:
How to Modify Ford Single Overhead Camshaft Engines
by David Vizard
Amazon have got it with 30% off at the moment.
It goes into all kinds of detail about getting the most power from the pinto with the least cost,
whats good and bad about the standard parts.
There are some really simple things that appear
to be very effective.
I *think* from memory that one of the types of
carbs is quite good, and the others not so. I can
check tonight if I remember.
Tim
greggors84
posted on 23/7/04 at 02:35 PM Reply With Quote
Yes, you would get a fair bit more power from a set of DCOEs
Chris
The Magnificent 7!
