Author: Subject: Nissan 200sx engine (CA18DET) complete with gearbox, ECU, Front section of prop, Loom etc etc
keljon
posted on 22/6/11 at 08:15 AM Reply With Quote
Nissan 200sx engine (CA18DET) complete with gearbox, ECU, Front section of prop, Loom etc etc, basically everything required to bolt the engine and gearbox into another car. The engine has been stripped for inspection and rebuild, these engines are capable of up to 700BHP depending on how deep your pockets are. Everything has been bagged up and boxed, most parts have been washed, the crank is standard size and does not require grinding for re-assembly, i removed this engine from the donor car myself so made sure it was a good one before i started. The flywheel and turbo are not included, the flywheel required skimming so i was planning on replacing it anyway so it has been thrown away and i had always planned on upgrading the turbo to a larger unit so the standard one was sold.
Offers around £400, i am located in Plymouth Devon and can be contacted anytime on 07595 820666
Some pics of the engine being stripped are here http://lcrep.blogspot.com/
blakep82
posted on 22/6/11 at 11:10 AM Reply With Quote
________________________
RichardK
posted on 26/6/11 at 07:12 AM Reply With Quote
Gallery updated 11/01/2011
Ninehigh
posted on 27/6/11 at 08:22 PM Reply With Quote
keljon
posted on 28/6/11 at 06:08 AM Reply With Quote
thanks for the free bumps guys pmsl
Ninehigh
posted on 28/6/11 at 06:27 AM Reply With Quote
keljon
posted on 11/7/11 at 09:54 AM Reply With Quote
bump
