Author: Subject: MEWP's
liam.mccaffrey
posted on 29/6/11 at 02:13 PM Reply With Quote
MEWP's
Mobile Elevated Work Platforms
Anyone aware of a machine or system which can lower the work platform below the level where the MEWP is?
IE for working on the underneath of elevated road ways or bridges?
Build Blog
Build Photo Album
fesycresy
posted on 29/6/11 at 02:22 PM Reply With Quote
Yes, this is where I get my access equipment from.
AJ Access
Give them a ring, if I understand your question right, any cherry picker should do?
Ben_Copeland
posted on 29/6/11 at 02:29 PM Reply With Quote
AJ Access
No most cherry pickers won't go down below their base.
That's into special equipment.
I'm on a "boom" at the moment and it won't go very far past it's base.
Ben
Locost Map on Google Maps
Enter Your Details Here
Guinness
posted on 29/6/11 at 02:30 PM Reply With Quote
I've never found a MEWP that can reach under itself. Even Genie Z series are limited to ground level works.
http://www.genielift.com/pdf/rom/Z-45_25J_Z-45_25JRT_ROMC.pdf
However facelift do a specific range of machines for this sort of work?
http://www.facelift.co.uk/hire/underbridge/moog-230x
However I suspect they are not cheap.
Could you get a machine with a long reach from below?
I've operated spiders with a 32m outreach?
Richard Quinn
Facelift have the ones for working over the side of bridges and back under the deck.
FACELIFT
Ben_Copeland
posted on 29/6/11 at 02:32 PM Reply With Quote
I've seen lorry mounted working platforms on the m2 bridge. But it was the only one I've ever seen come back under itself or below it's base.
It had special out riggers etc etc
Ben
Guinness
Just found a Genie Boom that can get you 10 foot below GL, but that is only any good if you don't have to reach over barriers etc. Plus it's only going to get you to the side, rather than fully underneath something.
http://www.genielift.com/pdf/rom/S-125_ROMC.pdf
liam.mccaffrey
posted on 29/6/11 at 03:11 PM Reply With Quote
This might work linky, problem is it over water so can't really get at from below without working from a barge
Thanks chaps for all the suggestions, good work
[Edited on 29/6/11 by liam.mccaffrey]
Build Blog
Build Photo Album
