Author: Subject: Raceleda Brake Nipples for M16 4 Pot Callipers
Krismc
posted on 3/7/11 at 06:10 AM Reply With Quote
Can i get them off the shelf anywhere, or can some one tell me what thread etc they are id rather change them too a size where i can put a metric spanner on while im at it. 8 nipples at the front.
Motor world dont do them and i popped into ATS on off chance and they dont have any.
When you do a google search, Rally design appear to have them but i cant find them on there site.
[Edited on 3/7/11 by Krismc]
Ben_Copeland
posted on 3/7/11 at 07:00 AM Reply With Quote
http://www.ebay.co.uk/itm/2-x-m10-BLEED-SCREWS-m16-Caliper-Escort-1-2-3-4-5-/230640989100#ht_505wt_922
That any good? Not sure why they need to be raceleda tho?
Ben
Locost Map on Google Maps
Enter Your Details Here
Krismc
posted on 3/7/11 at 07:03 AM Reply With Quote
Because im sure they are not metric on the raceleda callipers, the brass section is 11mm spanner and the bleed nipple is slightly bigger than a 6mm (6.25mm according to my callipers) but im not sure on the thread.
Ben_Copeland
posted on 3/7/11 at 07:06 AM Reply With Quote
I see now. Did a bit of hunting on google.
Can you ask mnr?
Ben
Krismc
posted on 3/7/11 at 07:07 AM Reply With Quote
I just want to order them or pick them up asap. Thought someone might have a easy option.
Krismc
posted on 3/7/11 at 07:12 AM Reply With Quote
Or a exploded diagram with the sizes on??
expatkiwi
posted on 3/7/11 at 07:44 AM Reply With Quote
Think Automotive in twickenham
I have decided to call my Westfeild "The Caterhammer" Hopefully it will
Krismc
posted on 3/7/11 at 07:51 AM Reply With Quote
Nope. And they dont know the size either
expatkiwi
posted on 3/7/11 at 08:00 AM Reply With Quote
Well I am stumped then. I would let you have mine but the new owner of the car might not appreciate it.
Good luck
posted on 3/7/11 at 08:11 AM Reply With Quote
Just buy a 1/4" AF spanner! if the hexagon is in imperial then it's likely that the threads are something like 1/4"UNF and there is no metric thread that will fit
Krismc
posted on 3/7/11 at 08:21 AM Reply With Quote
The last person didnt use the correct spanner and now they are foo bar-ed, hence why i need new ones
maximill666
posted on 3/7/11 at 11:01 AM Reply With Quote
The Raceleda calipers are manufactured by Outlaw in the states, but branded as Raceleda.
Supplied by Outlaw to various other companies also
The inlet & bleed screw threads are 1/8 NPT
Link to Outlaw M16 Calipers
Krismc
posted on 3/7/11 at 02:14 PM Reply With Quote
Cheers mate, mine also have 1/8npt written on them but i thought that was the flexi size.
Still cant find any in uk
thefreak
posted on 4/7/11 at 01:49 PM Reply With Quote
The Outlaw caliper looks identical to the Wilwood Billet Dynalite
http://www.rallydesign.co.uk/product_info.php?cPath=562_588&products_id=8305&osCsid=c9u50db0nvu6lel7ca2kk81si7
which use a 1/4" fitting so I would think the bleed nipples would fit too. They're only a few ££ from RallyDesign, and they're next day delivery.
