Author: Subject: mega/microsquirt setup help
beaver34
posted on 11/7/11 at 07:46 PM Reply With Quote
hi,
my mate has a subaru ej20 engine in a t25 vw camper, im new to this ecu, we have it running but are wanting to get a lambda reading to make sure its not too lean or rich, it has a standard subaru narrow band lambda, he showed me the engine running with the dashboard like view but it did not give lambda reading like normal it was just volts? how do we get this sorted so we can make sure it not too lean,
thanks alastair
mikemph
Contributor
Posts 111
Registered 20/9/10
Location oxford
Member Is Offline
Photo Archive Go!
Building: R1 powered Haynes Roadster and MK Indy zetec turbo
posted on 11/7/11 at 08:45 PM Reply With Quote
I think you right click on the gauge and then you can alter the way it displays. Can't remember off the top of my head.
Are you using megatune or tunerstudio?
mikemph
Contributor
Posts 111
Registered 20/9/10
Location oxford
Member Is Offline
Photo Archive Go!
posted on 11/7/11 at 08:46 PM Reply With Quote
I forgot to say the narrow band will only show rich or lean but not how much!
