Author: Subject: Rover v8 manifolds headers
Kitt
posted on 11/7/11 at 09:47 PM Reply With Quote
I've got a rover v8 powered WLR and need headers/manifolds for it.
I've bought some hedman headers but they are far to long and hit the floor (WLR has a belly pan under the engine) and still need to go approx 6 inches lower to Line up with the ports.
Then the collector faces the bulkhead so the rest of the exhaust would Want to go through the driver so it will also need rotating outwards.
Does anybody know what exhaust manifold and system is used on a locost v8?
I was looking at westfield manifolds but they are a little expensive if they don't fit.
I don't really Want to chop the hedmans up if there is a manifold out there that fits a treat.
Any ideas peeps?
I'm also after a prop for the LT77 to Sierra diff.
Thanks in advance
Dave
deltron63
posted on 11/7/11 at 10:09 PM Reply With Quote
try mgb v8 blockhuggers
Simon
posted on 11/7/11 at 10:15 PM Reply With Quote
I'm using modified SD1 manifolds.
Autoprop in East Grinstead made my prop but their website seems down so don't know if they are still going.
Welcome btw.
Simon
jollygreengiant
posted on 11/7/11 at 10:25 PM Reply With Quote
Prop shafts = Bailey morris linky
JD
Nuff said.
craig1410
posted on 11/7/11 at 11:21 PM Reply With Quote
+1 for Autoprop - they made my RV8 to Sierra prop too.
http://www.autoprop-uk.co.uk/
Welcome btw.
Simon
Agriv8
posted on 12/7/11 at 07:36 AM Reply With Quote
re headers my first thought was late range rover ones. I have some unused in the garage so can measure up if you like.
let me know and i will post up some pictures
they look like this
regards agriv8
[Edited on 12/7/11 by Agriv8]
Kitt
posted on 12/7/11 at 08:58 AM Reply With Quote
Thanks for the swift replys guys.
The range rover ones look like the downpipe knukle my get in the way On the drivers side, steering shaft to rack.
But messurments would be fantastic if possible.
Anybody got any pictures of their setup so I can get some ideas please?
posted on 12/7/11 at 09:05 AM Reply With Quote
I have them in the F27. I'll take a couple of snaps later today of them.
They do come tight to the steering column... in fact, I think one of the pipes has been given a slight 'knock' to give it the necesary clearance!
It's Evolution Baby!
Kitt
posted on 12/7/11 at 10:32 AM Reply With Quote
I don't mind a bit of tweaking at all but the way my hedman lines up it needs a tunnel boring through the middle of all 4 pipes to clear the colum LOL
posted on 12/7/11 at 12:58 PM Reply With Quote
Kitt
posted on 12/7/11 at 05:04 PM Reply With Quote
Cheers for the pics
Um they look a lot better for space than I thought they would.
What was modded on them do you know?
posted on 12/7/11 at 05:24 PM Reply With Quote
No mod as such... just a wee tap with a hammer to one of the primaries to create space for the steering-column. Probably an indentation of 1-2mm.
Agriv8
posted on 13/7/11 at 06:31 PM Reply With Quote
some photos for you
originals are in here ( taken with phone as all thats acvailable ATM ) LocostBuilders » Photos » Agriv8 » v8photo
header1
header1
header2
header2
header3
header3
header4
header4
all very approx let me know if you need more
regards
Agriv8
StuartBJ
posted on 17/7/11 at 08:41 PM Reply With Quote
Any ideas peeps?
Thanks in advance
Dave
Hi Dave, good to see another WLR on here. Have you just started your build? Part built?
Would love to see some pictures
All the best
Stuart
