Great NEW lighting products!!
OK, hows this for clever? Wind powered LED daytime running lights!, No wiring, no batteries, no switches just fit to your car & forget - fully
waterproof & weatherproof. Remove the "Cloak Of Invisibility" from your Seven. The wind turbine kicks in from around 10mph &
starts to give good visible light from around 15-20 Mph, so by the time you are doing 30mph plus they are highly visible even on a bright sunny day
[img]
![](/galpreviews/) ![](/gallery/)
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
They are fitted in seconds with double sided tape already fitted to the attached bracket & will fit just about any car, truck, bike, quad, boat,
jetski or anything else capable of more than 15mph. Before anyone asks - no they won't pass IVA as you can't switch them on & off!
(Tho' you can test they work just by blowing over the turbine). You never know, these could save your life!
I have them on The Bay at £15.99 a pair, to you guys (providing we are dealing direct) just £12.95 +£1.99 P & P per pair
I also have normal wired 8 LED DRL's at just £7.99 a pair, pics below
[img]
[/img]
[img]
[/img]
