Author: Subject: Swapping ford diff for landrover diff
scoop
posted on 19/7/11 at 12:42 PM Reply With Quote
Is the swap to the landrover 4.1 diff a straightforward one from the sierra 3.62 i have in at the moment and if so whice one do i want?
MK9R
posted on 19/7/11 at 02:13 PM Reply With Quote
are you on about a freelander diff? if so they are 3.21:1
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
scoop
posted on 20/7/11 at 08:29 AM Reply With Quote
I have read many times about people using the freelander 4.1 diff but didnt know if it just bolted in and you use the sierra drive shafts
MK9R
posted on 20/7/11 at 08:35 AM Reply With Quote
the freelander 1 diff will require different drive shaft and prop lengthening. The ratio is 3.21.:1 not 4:1, they only made one ration
[Edited on 20/7/11 by MK9R]
Cheers Austen
RGB car number 9
www.trackace.co.uk
Doctor Derek Doctors
posted on 20/7/11 at 12:51 PM Reply With Quote
I'm sure Westfeild did a 4.1 Ratio Freelander Diff, but it may have only been for the LSD's they supplied, I say this becuase I'm actually picking one up tonight from another LCB'er so I'll confirm that it is 4.1:1 ratio.
As for the conversion it will be a case of some new mounts (not to hard) and some new driveshafts, these will either have to be made bespoke or you have to cut them and have them sleeved and welded.
Some stuff from WSCC here about 4.1 ratio Freelander Diffs
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=Print;f=3;t=76141
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
MK9R
posted on 20/7/11 at 04:53 PM Reply With Quote
Maybe there is an aftermarket 4.1 freelander crown wheel and pinion set, but in standard form landrover only ever supplied a 3.21 in the freelander 1.
Cheers Austen
RGB car number 9
www.trackace.co.uk
sjmatthews
posted on 20/7/11 at 06:23 PM Reply With Quote
Scoop
Why not just change the ratio of you Sierra diff, which would be a lot less work?
I have a 3.92 7" open Sierra diff you may be interested in. It's in excellent condition, just removed it from my Fury to fit a 3.62.
I'll be in the garage dear!
Kev36
posted on 20/7/11 at 06:56 PM Reply With Quote
newbie question whats the difference between 3.61 to a 4.1 anyway.
' A rich man is just a poor man ...with an awful lot of money..'
adithorp
posted on 20/7/11 at 07:06 PM Reply With Quote
One does 3.61 turns of the input shaft (prop) for one turn of the output shafts (halfshaft/driveshaft/wheel). The other does 4.01... In other words a 4.01 is lower geared and revs higher for a given speed.
[Edited on 20/7/11 by adithorp]
http://jpsc.org.uk/forum/
Kev36
posted on 20/7/11 at 07:20 PM Reply With Quote
thanks , so for economic motorway driving, diffs in the low 3s are best?
daniel mason
posted on 20/7/11 at 07:43 PM Reply With Quote
depends what engine your running kev! some engines would be a waste of time with a diff ratio in the low 3's
Kev36
posted on 20/7/11 at 08:00 PM Reply With Quote
ive got a 1600 xflow , seems to rev high when doing 70. 5 gears type 9
sjmatthews
posted on 20/7/11 at 08:56 PM Reply With Quote
How many revs at 70?
Kev36
posted on 20/7/11 at 11:40 PM Reply With Quote
the rev counter is a bit knackered it hovers between 3500 and 5500 back and forward,
