Author: Subject: Zetec engine blown help needed please
lee987lee
posted on 23/7/11 at 01:18 PM Reply With Quote
I have a mondeo zetec silver top engine in my locost 7 but it's packed in and I need a new one.
Will a focus engine or a mondeo black top engine fit straight in as there is more of them to pick from?
I'm just wanting a straight forward swop over any ideas are welcome
Thanks Lee
macc man
posted on 23/7/11 at 03:38 PM Reply With Quote
Should be a straight swap. Only minor detail mods between the engines. Water pump & thermostat housing is different but essentially the same engine. Good luck.
posted on 23/7/11 at 03:46 PM Reply With Quote
Straight swap really, what happened to the silver top?
perksy
posted on 23/7/11 at 04:21 PM Reply With Quote
Aren't the engine mounts different ?
AntonUK
posted on 23/7/11 at 04:42 PM Reply With Quote
I too were wondering this as my current silver is knackered but black top's are much easier to get hold of.
Gazeddy
posted on 23/7/11 at 04:47 PM Reply With Quote
black top and silver tops are different but early black tops are nothing more then re topped silver tops. if it says zetec se or duratec its no good to you with the exception of the st170 lump and the mk1 rs focus lump. which are silvertops in drag
lee987lee
posted on 23/7/11 at 05:28 PM Reply With Quote
Bottom end n piston number 2 are both shagged
lee987lee
posted on 23/7/11 at 05:29 PM Reply With Quote
I have the st 170 in at the moment and I'm wanting to keep the 170bhp. So I think I'm just going to look for a bottom end
paulf
posted on 23/7/11 at 08:51 PM Reply With Quote
Engine mounts and alternator mount are different as well as the alternator belt routing which needs an idler,the water pump outlet is a different diameter and angled differently.I changed from silver top to black top so am quoting from experience, also if you have a modded sump the silver top sump is not a direct replacement onto a black top but can be made to fit.
If its a silver top then it is not an ST170 engine.
Paul
posted on 24/7/11 at 01:54 PM Reply With Quote
If you want a straight swap then look for a silver top. The black top is definitely not a straight swap for most installations.
