Antnicuk
posted on 25/7/11 at 07:40 AM |
Can I make my own Braided brake line to suit length?
I want to replace some of the copper brake lines and it would be much better if i could make them in braided lines. Can i buy the hose and the
fittings and make them at home to be safe enough?
if so, can anyone recommend a good place to get bits?
tomgregory2000
posted on 25/7/11 at 07:50 AM |
Yes you can.
Look for any goodridge hose stockest, you can buy the line and compression fittings.
I made my own clutch lines this way
Edit: temon tweeks do the bits but at a price
[Edited on 25/7/11 by tomgregory2000]
edsco
posted on 25/7/11 at 07:54 AM |
Yeah course its possible. Very easy to do. Rally Design is where i bought my bits and bobs from. Not the cheapest, many other places can supply
same parts cheaper. Do web search. Braided hose it expensive so make sure you measure well. Like with the olives...if you can afford it, over order
slightly.
Make sure you purchase more 'olives' than you think you require as it easy to make a mistake. Note of caution: braided hose can rub
bodywork chassis rails and is quite abrasive, so make sure it properly secure.
edsco
shindha
posted on 25/7/11 at 08:08 AM |
I would like to do the same, have a look at this website and I think it might be something to do with some one on here, don't know how the
prices compare.
link
matt_gsxr
posted on 25/7/11 at 08:18 AM |
Agree with above, you can build them, they can pass SVA and they work (I have braided only on mine, front to back).
If you don't want the bother, faff and stainless wires in your fingers that you get from making these hoses, then goodridge do a modular system
(build-a-line), where you can buy pre-ended hose and connectors. They are designed for the motorcycle market. I have used one and the quality is
good.
Here are some details.
http://www.goodridge.net/documents/downloads/retail/UK/UK_Buildaline_AppGuide.pdf
http://www.brakes4u.co.uk/Goodridge_Motorcyle_Build_a_.asp?sortit=6&pg=4
You can often pick the bits up cheap on the well known auction site.
Matt
edited for better link
[Edited on 25/7/11 by matt_gsxr]
BigMac
posted on 25/7/11 at 09:33 AM |
You could make your own, or U2U 'Russbost' on here. He made all my braided lines for a very good price, a better job than I could have
done for the price if you were to include the tooling you'd need. He'll make them to the specific length you specify, too!
RACER101
posted on 25/7/11 at 09:45 AM |
Try Pip Gardener at WGT Autodevelopments in Middlewich (pretty close to where you are) on 01606 837277.
He will be able to source all the pipes, end fittings & olives etc. that you need.
Pip has tons of experience with race cars & kit cars etc and also has rolling road facilities which could be very useful to you when it comes to
set up time.
Good luck,
John
eddie99
posted on 25/7/11 at 09:48 AM |
+1 for Russbost, im sure his prices are probably cheaper than you doing it yourself getting all the various tooling and parts..... And its being done
by a professional. Obviously if you want to do everything on your car then do what the people above say and make your own
RACER101
posted on 25/7/11 at 09:49 AM |
Ooops, I thought BigMac was the OP and therefore suggested a supplier close to him..............that will teach me to try and read & type whilst
wearing my new 'distance' contact lenses instead of my reading specs /doh
Antnicuk
posted on 25/7/11 at 10:44 AM |
thanks all, I have known Pip for over 20 years, being a rotary fan since i was 17 but unfortunately he is not local to me.
I have messed about with braided hoses for oil lines and it is horrible stuff to work with when making the compression fittings so if there is someone
who is willing to make them at a reasonable price, it sounds good to me.
thanks again
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
BigMac
posted on 25/7/11 at 11:13 AM |
:-P Thanks matey, funnily enough, I know of Pip- he built a mutual friends triple rotor RX7!
blakep82
posted on 25/7/11 at 11:25 AM |
correct!
plus the type of fitting you can buy are usually screw together, which some IVA testers don't seem to like for brake systems in case they
unscrew, or are un screwed , Russ's ones are properly pressed and swaged together, and are PVC coated in a range of colours
________________________
eddie99
posted on 25/7/11 at 11:27 AM |
Pretty
matt_gsxr
posted on 25/7/11 at 01:13 PM |
Build-a-line system is swaged.
Making braided brake hoses is about 100x easier than those nasty braided oil hose, which is a real nightmare (for me anyway).
