liam.mccaffrey
| posted on 27/7/11 at 08:48 AM |
Long bolts
I'm looking for a supplier of either 10mm 12mm 3/8 7/16 1/2 bolts with very long un-threaded section 6 to 8 inches. Any ideas?
Build Blog
Build Photo Album
Bigboystoys
| posted on 27/7/11 at 09:25 AM |
There are a couple of company's on eBay, type the bolt spec in the search and see what comes up.
minitici
| posted on 27/7/11 at 10:37 AM |
A-Series Spares do UNF/UNC socket head and hex head bolts (12.9 grade) up to 6" long and have long unthreaded portion.
(threaded about 1-1/2"
Tiger Super Six
| posted on 27/7/11 at 11:55 AM |
Google Astley Components (Feering) and DJ Evans (Bury St Edmunds) - they both have a good supply.
Mark
Tiger Avon
James
| posted on 27/7/11 at 12:17 PM |
These guys have always helped me with any weird ones I need. And they deliver too:
http://www.ahc-camberley.co.uk/catalog/index.php
James
- Muhammad Ali
CNHSS1
| posted on 27/7/11 at 09:42 PM |
Non Standard Socket Screw Company in Birmingham
liam.mccaffrey
| posted on 27/7/11 at 10:18 PM |
Thanks guys I'll let you know how I get on
Build Blog
Build Photo Album
Doctor Derek Doctors
| posted on 28/7/11 at 12:57 PM |
SCH's (Socket Cap Head) have a thread length that is dependant on thread Diameter (rather than bolt length. So a 6" Long bolt will have
the same length thread as a 3" long bolt. This means that a standard SHC will have a long un-threaded area if it is a long bolt (if that makes
any sense).
So if you order a 10" Long standard M8 SHC (for instance) most of that will be unthreaded. Set Screws on the hand are threaded over there entire
length.
Namrick do standard bolts upto 150mm Long (~6" in there standard Catalogue. For example 6" Long 7/16 UNf Bolt = £2.66.
You should be able to find a wealth of information here:
http://www.roymech.co.uk/Useful_Tables/Screws/index_screws.htm
Hopefully will be of use Liam.
Edit: Liam I have just realised that I have a load of large size and Long 12.9 grade Metric Cap Heads in my garage, you can have a load if they are
what you need.
[Edited on 28/7/11 by Doctor Derek Doctors]
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
