New Topic New Reply
Author: Subject: mushrooms on my mk
whitstella
posted on 28/7/11 at 03:43 PM Reply With Quote
mushrooms on my mk
i need to tighten and bolt my front mushrooms but i'm not sure where is the best position for selfcentreing.
cheers steve
Ben_Copeland
posted on 28/7/11 at 04:00 PM Reply With Quote
Oh no. Can of worms again.
Perhaps do a search because this will set off another argument about castor etc.
You want the upright to lean back as much as possible.
Ben
Locost Map on Google Maps
Enter Your Details Here
mookaloid
posted on 28/7/11 at 04:09 PM Reply With Quote
Yep hole to the front
ReMan
posted on 28/7/11 at 04:21 PM Reply With Quote
Wherever looks nicest
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
PSpirine
posted on 28/7/11 at 04:44 PM Reply With Quote
Yes, can of worms
Turning the mushroom does not change the upper upright pivot point, which is in the centre of the BALL JOINT. The castor imaginary line goes between the top ball joint centre and the bottom ball joint centre.
Castor will NOT change.
It will effectively raise (very very slightly) the steering rod end pivot point but I do not see how that will help with your self-centering.
posted on 28/7/11 at 05:05 PM Reply With Quote
Originally posted by PSpirine
Yes, can of worms
100% right.
z3mjason
posted on 29/7/11 at 01:47 PM Reply With Quote
Noobie question,
Sorry but whats a mushroom??
Jason
posted on 29/7/11 at 03:12 PM Reply With Quote
Originally posted by z3mjason
Noobie question,
Jason
A conversion adaptor for Sierra suspension it is bobbin that replaces the end of the Macpherson strut to provide a tapered hole to allow provide a location for the top wishbone's ball joint (actually a Transit Drag link end)
[Edited on 29/7/11 by britishtrident]
z3mjason
posted on 30/7/11 at 02:47 PM Reply With Quote
Understood! Thank you...
andersmartensson
posted on 9/8/11 at 08:15 AM Reply With Quote
The hole should be at 11 on the clock assuming 12 is front.
Make sure you have at least 3dg camber my exp is that 5dg camber is working perfect on the track.
But it's also pending on the tires you have.
I used Kumho ecsta w700 soft 215/50 - 13" front and 235/45 rear.
cheers
Anders
if you are in control - you arn't going fast enough.
mad-butcher
posted on 9/8/11 at 11:34 AM Reply With Quote
Surely you can't have both mushroom holes at 11 o'clock.
if the left hand one is at 11 o'clock then the right hand one must be at 1 o'clock
likewise
if the right hand one is at 11 o'clock then the left hand one must be at 1 o'clock
or am I missing something
tony
New Topic New Reply
