<<  1    2    3  >>
Author: Subject: Monday puzzle - which way will the little cart go?
posted on 1/8/11 at 11:26 AM Reply With Quote
Here's something to think about...
Look at this picture:
It shows a little cart made with a couple of bobbins that that can rotate freely. A big wheel sits on top of the bobbins - if you push the cart, the big wheel rotates in the opposite direction to the bobbins. OK so far?
Now if a ruler is put on top of the big wheel and is pushed to the right, which way will the cart move, and how fast (roughly)?
I'll post the answer in a couple of hours!
posted on 1/8/11 at 11:30 AM Reply With Quote
Depending on the coefficient of friction between the different materials the piece of paper inder the cart should move in the same direction as the ruler is moving and the cart will stay where it is.
blakep82
posted on 1/8/11 at 11:31 AM Reply With Quote
does it goes left, roughly 3 times faster than you move the ruler?
no, change my mind, it doesn't move at all! go with that, because the little wheels won't have enough power to them to overcome you dragging the whole thisng the other way with the ruler
[Edited on 1/8/11 by blakep82]
________________________
mookaloid
posted on 1/8/11 at 11:36 AM Reply With Quote
Looks to me like it will move towards the hand
richardlee237
posted on 1/8/11 at 11:37 AM Reply With Quote
it will move to the left and the monkey gets his nose cutoff
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
ReMan
posted on 1/8/11 at 11:48 AM Reply With Quote
Whizz to the lion?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
matt_gsxr
posted on 1/8/11 at 11:58 AM Reply With Quote
Top of wheel moves in same direction as the cart, but way slower.
Pushing on ruler will result in cart moving fast in the direction that ruler is pushed.
Ratio distance move is the same as the ratio bobbin diameter to bobbin-outer minus bobbin-inner diameters.
Go on show us the video
Agriv8
posted on 1/8/11 at 12:04 PM Reply With Quote
depends if you intend to be on Penn and teller next weekend ?
Best bit of Saturday TV that IMHO
regards
Agriv8
loggyboy
posted on 1/8/11 at 12:13 PM Reply With Quote
2nd EDIT: Id go with this answer.
(i just used a cd and a £1 coin to simulate!)
[Edited on 1/8/11 by loggyboy]
craig1410
posted on 1/8/11 at 12:14 PM Reply With Quote
It will move in the same direction as the ruler, to the right and at a faster rate than the ruler is moving in relation to the ground. I had to think about it for a minute though...
My thinking goes like this:
1. There is only one external force - that of the ruler applying a force from left to right.
2. This will apply a clockwise force to the bobbins which will in turn apply a counter-clockwise force to the big wheel.
3. The force on the big wheel is working against the external force from the ruler but because of the gearing the force on the bobbins will "win".
4. Therefore the cart will move right but at several times the speed of the ruler due to the large wheel rotating against the ruler's tangential direction.
I hope that makes sense...
[Edited on 1/8/2011 by craig1410]
loggyboy
posted on 1/8/11 at 12:16 PM Reply With Quote
It must move to the left as the secondary large wheel will reverse the travel.
Dingz
posted on 1/8/11 at 12:18 PM Reply With Quote
Opposite direction to ruler, same speed.
went on and on.
Humbug
posted on 1/8/11 at 12:19 PM Reply With Quote
Assuming that the paper doesn't move the cart must go left if the ruler is pulled to the right.
ETA I think that the ruler will not move in absolute terms (i.e. in relation to the table), but it will move to the right relative to the top of the wheel at the same speed as the cart moves to the left (relative to the table). Make sense? It does in my mind!
[Edited on 01.08.2011 by Humbug]
posted on 1/8/11 at 12:30 PM Reply With Quote
Matt & Craig have got it right!
Video of cart
(the video's a bit stupid, but he does demonstrate how it works - and it looks weird!)
loggyboy
If the bobins were the same size of the wheel that would be correct, but the ratios will mean the ruler will move to the right slightly slower than the cart moved to the left.
loggyboy
posted on 1/8/11 at 12:33 PM Reply With Quote
Video of cart
The ruler IS being pushed to the opposite diection, however the travel of the cart makes it looks like the ruler is being pushed in the same direction.
craig1410
posted on 1/8/11 at 12:35 PM Reply With Quote
Video of cart
Eh? The ruler is being pushed/pulled/whatever from left to right and the cart is moving from left to right. How is that opposite?
Cool video David
posted on 1/8/11 at 12:38 PM Reply With Quote
Video of cart
I know what he means - in fact the ruler IS going backwards as far as the big wheel is concerned - the little wheels are driving the cart so fast that *to the big wheel only* the ruler's going the other way - relative to itself.
loggyboy
Cool video David
The rulers direction of movement in relation to the table is nothing to do with the direction in which force is being applied.
craig1410
posted on 1/8/11 at 12:40 PM Reply With Quote
Okay I think I get you now - I was thinking in terms of motion not force. Sorry.
Madinventions
posted on 1/8/11 at 12:48 PM Reply With Quote
The only way that could've been more awesome would be if Johnny Ball did the voice over...
View my band website:
http://www.shadowlight.org.uk
loggyboy
No need to be sorry!, I love this sort of discussion.
But the wording of the OP is if 'you' move the ruler to right.
Sadly the OP was looking at the optical illiusion and assuming the input of the hand is moving the ruler in the direction of the cart, when in fact its the cart that is moving the ruler, but the input of force from the hand is in fact pushing the ruler in the opposite direction to that in which it 'appears' to travelling in.
posted on 1/8/11 at 01:02 PM Reply With Quote
This OP disagrees - there is no optical illusion - the ruler IS moving from left to right.
However, as I said earlier, the position of the ruler relative to the big wheel is right to left, which is why the cart does what it does.
I was not confused about what I saw - I was simply impressed by the mechanical aspects of the 'trick' (of course, it is no trick).
loggyboy
posted on 1/8/11 at 01:04 PM Reply With Quote
But you were wrong to say that craig and matt were correct. lol - this is getting complicated!
russbost
posted on 1/8/11 at 01:18 PM Reply With Quote
If the ruler moves from left to right it must push the large wheel in a clockwise direct - that is NOT what is shown in the video! If the large wheel was rotating clockwise the cart would move to the left as the bobbins rotate counter clockwise, so I would say there is an optical illusion there, all to do with the gearing & therefore the perceived motion of the ruler surely! IMHO of course
<<  1    2    3  >>
