Author: Subject: Why doesn't my Indy-Blade dound like a Fireblade ??
tompat3463
posted on 8/8/11 at 09:14 AM Reply With Quote
as the title really.
obviously there may be some problems with what I'm running but my indy-blade doesn't sound like a bike..
its running with an MK silencer.. Thye sound my Indy-blade makes is alot more throatier than I a bike..
A bike sounds very crisp and clean when its reved i think but like I say my car sounds very throaty and deep.
could this be reverberation from other car components ??
or is it just the MK silencer ??
Does anyone else have this "problem" ??
I call it a problem because I would like my girlfriend to come on some drives with me but she absoloutely hate the noise that it makes.
Personally I don't find the noise awefull just a bit crude and sometimes it sounds like a bloody chav chariot when I'm going thru small villages !!
I know its a bit of a weird question but any help would be great
cheers Alan
[Edited on 8/8/11 by tompat3463]
Yazza54
posted on 8/8/11 at 09:25 AM Reply With Quote
Could always fit a bike can on it
tompat3463
posted on 8/8/11 at 09:29 AM Reply With Quote
do U think thats what it is ??
To be honest I'm not convinced that MK's silencer is the best as they leak loads and rattle like mad.. well that just mine..
cheers Al
pmc_3
posted on 8/8/11 at 09:54 AM Reply With Quote
Why not pick up a cheap secondhand bike can and give it a try? you could always upgrade it if you find thats the solution. I would of thought you could pick up a scruffy bike can for around £35
wilkingj
posted on 8/8/11 at 10:35 AM Reply With Quote
Why not try a posting in the Wanted section first. I bet someone has a spare can lying about you could try for the costs of the postage etc. Probably a cheaper option.
Worth a try.
Just my 2 reils worth
Best Regards
Geoff
http://www.v8viento.co.uk
ReMan
posted on 8/8/11 at 10:40 AM Reply With Quote
Mine does.
I found with both the R1 silencer and my current VIPER (cough competition use only) it sounds more like a bike than most of the bikes
[Edited on 8/8/11 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
adithorp
posted on 8/8/11 at 11:21 AM Reply With Quote
It's probably a combination of,
A, The larger bore, less restrictive, longer exhaust.
B, Different intake (if you don't have the standar air-box).
C, Tunning as a result of A+B (has it been re-mapped? )
D, Vibration from the bonnet/body panels
http://jpsc.org.uk/forum/
Davey D
posted on 8/8/11 at 11:50 AM Reply With Quote
Have you got the original airbox fitted, or do you have an open foam filter on a back plate? that will be making the engine sound different too
bi22le
posted on 8/8/11 at 11:53 AM Reply With Quote
To add to the above list I felt my old BEC sounded deeper when driven. It seemed that when the engine was put under load it deepended its tone. Rev it at the lights and it sounded more tuneful.
I think a different silencer will make a different noise. Weather you get away from the 'chav' noise is another matter. Unfortunatly they make their cr&p cars sound like our sporty ones!!
HTH.
If not then ear plugs. My wife always wears them if we go for anything more than a short drive. The car sounds a lot louder to the passenger (if the exhaust is on that side of course!)
Please read my ring story:
A1
posted on 8/8/11 at 12:00 PM Reply With Quote
also the exhaust could be sookin in air at any joins which will make it sound rougher...
is it the old style of silencer or the massive new one?
tompat3463
posted on 8/8/11 at 12:08 PM Reply With Quote
thanks for the opinions guys.. quite interesting..
Niot sure which exhaust it is.. if U have a lokk in my phto archive U may be able to help with that.
engine is running with sausage filter but im ok wit the sound of the engine jus the exhaust which sounds loud..
will a bike can make it quieter ??
will a bike can make it faster ???
cheers guys
kevmcdo
posted on 8/8/11 at 12:53 PM Reply With Quote
Sounds like it is just your can, if you park both A1's car and mine together which both have R1 engines the sound so different.
A1 has the MK silencer I think where I have a free flowing oval bike can.
On full chat both cars sound similar but as you said the MK does not sounds as crisp, a little duller.
Think your girlfriend may change her mind after sitting inch's away from an open bike end can though, its different on the bike as they are much lower and further behind your ears!!!
tompat3463
posted on 8/8/11 at 04:27 PM Reply With Quote
yeah.. I think I like the crispier bike sound more than the earth moving rumble...
haven't got money to soend on it yet so i'll probably try and find a FREE bike can and try that... cheers guys
kevmcdo
posted on 13/8/11 at 06:39 PM Reply With Quote
Got my Oval can ( identical to a viper ) for £35.00 brand new direct from Germany, no markings on it at all and it is very free flowing
johny p
posted on 13/8/11 at 08:09 PM Reply With Quote
get a stubby bike can mate..mine sounds the bollocks...
mangogrooveworkshop
posted on 13/8/11 at 08:25 PM Reply With Quote
Give her earplugs cost 50 p or a new girlfriend for a £100 000
