Author: Subject: R1 Cooling fan not kicking in
Kriss
posted on 9/8/11 at 04:29 PM Reply With Quote
Hi all,
My fan normally kicks in at 97ish (ont he koso temp gauge) but at the Ring in traffic it hit 108 deg and still didnt kick in?
Its a %pw and I dont know were to start looking.
car was amazing out there by the way - not a BEC killer like so many say!
adithorp
posted on 9/8/11 at 08:36 PM Reply With Quote
If you're still on the bike loom and with an aftermarket fan (rather than the original it could just be the fuse. I had the original size in and the bigger fan blew it one day. Couldn't find any other problem so upper the fuse 5amps and been fine ever since.
http://jpsc.org.uk/forum/
fege
posted on 10/8/11 at 01:47 PM Reply With Quote
I'm having the same problem on my R1 MNR. The 7,5 A fuse blows when I engage the fan. The stock R1 fan is replaced by a bigger Pacet fan so I also suspect that I need to beef up the fuse.
[Edited on 10/8/11 by fege]
fege
posted on 10/8/11 at 06:13 PM Reply With Quote
I switched to a 10 A fuse when I got home from work and now the fan runs like it should.
Kriss
posted on 11/8/11 at 07:54 AM Reply With Quote
any ideas on location within the box though or fuse number?
r1_pete
posted on 11/8/11 at 08:01 AM Reply With Quote
Incoperating a relay in the circuit, switching the relay using the original fan wires, and a new high current feeds to the fan would be the 'elegant' solution IMO.
The original circuit was rated at 5 amps for a reason.
Proby
posted on 11/8/11 at 12:15 PM Reply With Quote
Exactly, very wise advice. Be very careful upgrading the rated fuse without upgrading the wiring.
fege
posted on 11/8/11 at 01:33 PM Reply With Quote
As said, a wise advice. In my case the wires have been upgraded.
Kriss
posted on 11/8/11 at 02:19 PM Reply With Quote
but where is the blimin' fuse homies lol
adithorp
posted on 11/8/11 at 02:46 PM Reply With Quote
Depends on the year of R1. On the 04-06 it's in the fuse box. Little black plastic box with "FUSES" on the top. Open the lid and there's a list in the lid (there's only 4 or 5 from memory). Where exactly thats been put on the car is difficult to guess.
fege
posted on 11/8/11 at 05:49 PM Reply With Quote
On my 4XV, if yo uhold the fuse box with the fuse marked "SIGNAL" towards you you should have a row of 6 fuses. The first from the right is 15A, the second 20A and then comes the 7.5A fan fuse. I hope this makes sense to you. If I remember correctly the remaining three fuses in the row are spares.
