Author: Subject: Which is better? turbo or supercharger!
spiderman01980
posted on 9/8/11 at 06:44 PM Reply With Quote
http://www.youtube.com/watch?v=MGdg2Fd2WQY
Toniq-r
posted on 9/8/11 at 06:59 PM Reply With Quote
Superchargerrrrrrrrrrrr of course power all the way through the gears! Thats If you have some spare $$$
TheGiantTribble
posted on 9/8/11 at 08:02 PM Reply With Quote
For me principly because the best sounding engine of all time was a R/R Merlin
I vote Supercharger :-)
Admitidly Turbos have overcome most of the things I don't like about them, but hell I like living in the past
Doctor Derek Doctors
posted on 9/8/11 at 11:03 PM Reply With Quote
F1 Engine Suppliers and All of the OEM's have chosen Turbochargers.... so theres your answer.
Turbochagers have overcome their limitation of lacking low end power but Superchargers cannot (by design) overcome their limitation of sapping engine power to run and being massively more expensive.
The supercharger (somewhat sadly) will soon be confined to Drag Racing, some 'halo' brands and the history books.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Litemoth
posted on 10/8/11 at 09:33 AM Reply With Quote
Both.....
http://www.youtube.com/watch?v=CmcTY2erGCk
and...
LINKY
[Edited on 10/8/11 by Litemoth]
westy turbo
posted on 10/8/11 at 09:56 AM Reply With Quote
Turbo
flak monkey
posted on 10/8/11 at 10:15 AM Reply With Quote
For road use, a supercharger wins out. There is no lag, the power is ther at all RPM in every gear which means less changing gears to keep it on boost. Supercharger will build boost prgressively with RPM as well.
For racing a turbo is cheaper and more reliable as there is no complex drive system to maintain.
Production cars use primarily turbos solely for cost reasons, so citing that as a reason for them to be better because 'all production cars use them' is quite frankly horse crap. But the new TFSI VW range all use both a supercharger and turbo.
The most powerful internal combustion engines built in terms of bhp/litre (top fuel dragsters) use superchargers as they want power all the way up the rpm range as they only have 1 gear.
So pay your money and take your choice really. A supercharger install will likely be more expensive but more refined in terms of power delivery.
Both are capable of making the same peak BHP with the same level of boost. But the torque curve from a good supercharger install will be much smoother than a good turbo install.
[Edited on 10/8/11 by flak monkey]
Sera
http://www.motosera.com
posted on 10/8/11 at 11:59 AM Reply With Quote
Production cars use primarily turbos solely for cost reasons, so citing that as a reason for them to be better because 'all production cars use them' is quite frankly horse crap. [Edited on 10/8/11 by flak monkey]
Its not horse crap as it depends on what your definition of 'better' is.
If you class 'better' as looking at the whole range of factors (Peak Performance, Rev Range Performance, Cost, Simplicity, Economy, Noise, Manufacturing Time, Maintainance, etc etc etc) Then the Turbo has the Supercharger licked in every area apart from low end grunt and nowadays thats not really even true as the new range of turbos have nigh-on eliminated that problem and the next generation of turbos will have totally eliminated lag anyway.
Working closely with IHI at the moment (a Turbo and Supercharger manufacturer) has thrown up a lot of info on Turbo and Superchargers, and the sad fact that superchargers now no longer have any real advantage over a turbo, most are sold at a loss and only used for the name and Halo brand effect.
As said the new F1 rules allow forced induction but none of us are going for a Superchager, its Turbochargers all the way.
www.t89.co.uk
callan@t89.co.uk
westy turbo
posted on 10/8/11 at 12:46 PM Reply With Quote
Throw us a dyno sheet Flak
flak monkey
posted on 10/8/11 at 01:19 PM Reply With Quote
Here you go dyno result from my 2 litre duratec with Rotrex supercharger, 0.67bar peak boost (blue line), power in green and torque in red
Sera
posted on 10/8/11 at 01:36 PM Reply With Quote
Turbochargers still have a definite boost threshold below which they don't do much. Turbochargers also require plenty of engine power to drive them, though not as much as a supercharger.
pewe
posted on 10/8/11 at 03:01 PM Reply With Quote
Having now driven both - tin-top turbos for years and supercharged Se7en for the last 3 my preference is for exactly that.
Turbos on tin-tops give great performance when you need it but for sheer low down grunt, hair trigger throttle and linear acceleration there's nothing quite like supercharged 650kgs.
Cheers, Pewe
spiderman01980
posted on 10/8/11 at 05:36 PM Reply With Quote
how much was your supercharger?
carnut
posted on 10/8/11 at 06:03 PM Reply With Quote
I'd say a turbocharger but with compounded drive to the crank so to extract maximum enthalpy from the exhaust gas.
DRC INDY 7
posted on 10/8/11 at 06:48 PM Reply With Quote
I say turbo because i have 1 in my mk indy and 1 in my vxr corsa
Puddle Dodgers Club
liam.mccaffrey
posted on 10/8/11 at 06:55 PM Reply With Quote
I don't care which is better really, I'm ditching my turbo on my volvo T5 and subbing in an Eaton charger because I like chargers more. Don't know why but i guess its the same kind of thing as me liking odd numbers better than evens.
Build Blog
Build Photo Album
flak monkey
posted on 10/8/11 at 08:19 PM Reply With Quote
Cant remember, think I paid about £800 for the kit secondhand.
Sera
Ivan
posted on 11/8/11 at 07:21 AM Reply With Quote
I think that either works well - if i were driving long distances , or even short, on a trailing throttle with zero boost I think I would go for a turbo to give great overtaking ability and low friction losses when cruising.
If most of my driving was track days I would go supercharger.
My personal preference is Turbos but I can see the advantages of superchargers as well.
westy turbo
posted on 11/8/11 at 10:40 AM Reply With Quote
Just to have 2 dynos sheets for people that are intrested,
1st one with 0.45bar and 270 hp,and second is at 1.05 bar and 390 hp,
u ca see that if the turbo is right,the lag doesnt exist.
ianclark1275
posted on 11/8/11 at 04:32 PM Reply With Quote
some useless info
turbos are used as this improves the CARNOT efficency. its that frenchman again.
a large capacity turbocharged engine has a better efficiency than a small non turbo.
thats why they are used on lots of cars now.
(the internal turbine on a ford turbo cost the ford motor company 55p to produce --so they are also cheap to build now.)
im sure i read something somewhere when a works rally mechanic was asked what he would prefer to fit to the car he said superchargers everytime. (it was probably on here!)
IC
measure twice, cut once, scrap it, start again.
posted on 11/8/11 at 04:58 PM Reply With Quote
WHAT ARE YOU PEOPLE ON?
Everyone knows that the electric superchargers on eBay are the best!
It's Evolution Baby!
posted on 11/8/11 at 07:03 PM Reply With Quote
Originally posted by ianclark1275
some useless info
I think you have that backwards. A small capacity turbocharged engine is (or can be under certain circumstances) more efficient than a larger capacity normally aspirated engine.
However, it's not the turbo that makes it more efficient; that is only bolted on in order to produce an adequate maximum power. To produce a given amount of power, a smaller displacement SI engine will be throttled less which reduces pumping losses and increases thermal efficiency due to increase in dynamic CR. The smaller turbo engines are increasingly having less cylinders as well (e.g. Fiat Multi-air and PSA 3 cylinder) which cut down on friction.
Under boost the mixture has to be richened for cooling purposes, which hurts economy. This is why people report such vastly different economy figures from these cars. Drive them gently, off-boost, and they can return impressive economy. Drive them like you stole them and they will be little better or maybe even worse than a larger capacity NA engine.
westy turbo
posted on 11/8/11 at 07:05 PM Reply With Quote
HP can be thirsty on demand
westy turbo
posted on 11/8/11 at 08:50 PM Reply With Quote
On this turbo,it maxes out it self at 1.35bar and 440,and we havent tried 2.2 bar with the new gtx3076 series that spools 200 rpm earlier and about 40-50 hp at the same boost,dont want to try that
