Author: Subject: Hazard switch
Roland
posted on 12/8/11 at 07:14 PM Reply With Quote
Hazard switch
Can anyone assist me in a wiring conundrum? I have an Escort MK2 7pin hazard switch. I have got a neater, round LED hazard switch, but it only has three terminals on.
My question is. How do I wire the three terminal switch so the hazards work. Do i need all seven wires from the old switch? If I do then what goes where?
Any help would be very much appreciated.
Roland
The faster you go, the bigger the grin !
Ben_Copeland
posted on 12/8/11 at 08:44 PM Reply With Quote
I'm guessing the 7 pin one has the flasher relay built in or designed to work with a different flash relay.
You'd have to change the wiring/ get a sierra flasher relay and rewire it all to work with the new switch.
Ben
Locost Map on Google Maps
Enter Your Details Here
RK
posted on 14/8/11 at 05:04 AM Reply With Quote
Some flasher switches are meant to have the indicators wired through them, and have the flasher relay built in. You may need to add this stuff to the new switch circuit.
