Author: Subject: Modding a pickup
liam.mccaffrey
posted on 25/8/11 at 07:32 PM Reply With Quote
Modding a pickup
How far can i go with modding a P100 pickup
I'm guessing changing the front suspension to a solid axle won't trigger an IVA, or will it???
What about shortening the chassis and bed? Anyone have any insight?
Build Blog
Build Photo Album
sprouts-car
posted on 25/8/11 at 08:39 PM Reply With Quote
Pretty sure any change to the chassis should require an iva. Think this will be the same from changing the suspension. Probably not the answer you were looking for. I'm sure someone will be along soon to confirm or refute.
Build blog
Humbug
posted on 26/8/11 at 06:45 AM Reply With Quote
Shortening the chassis definitely means you are not using the original unaltered chassis so would need IVA IMHO.
Changing the suspension should be OK as long as it is just bolted to the chassis.
snakebelly
posted on 26/8/11 at 06:48 AM Reply With Quote
As I understand it the key to suspension mods is that you have to use the original chassis mounts anything outboard of the mounts is fair game, just my interpretation
HowardB
posted on 26/8/11 at 02:29 PM Reply With Quote
I would ask this question in a Land Rover forum, there are hundreds of shortened Land Rovers about all on the original V5, often changed engines, suspension etc.
If my memory serves me correctly there is a points system for how much can be changed before it is not the original vehicle,...
hope that helps
Howard
FEZ1025
posted on 31/8/11 at 12:38 PM Reply With Quote
hope that helps
Or over in a Mini forum, on those forums anything goes, you can do whatever you want as long as you don't get caught. There are bike engined Mini's, rear engined Mini's, 4WD Mini's none, if any have been through SVA/IVA.
Alan...
