Author: Subject: I hate computers sometimes!!!
speedyxjs
posted on 2/9/11 at 11:21 AM Reply With Quote
I think my computer picked up a virus. AVG said the subscription had expired so i went online to try and redownload it but found i couldn't get on to any antivirus sites. I tried to download the likes of spybot but it wouldn't let me install anything so restarted my computer in safe mode and now it wont start. Just sees to be on a loop on startup
I lent my brother my only XP copy and he doesn't think he knows where it is. Before i buy a new Pc, is there anything i can try to get it sorted?
Charlie_Zetec
posted on 2/9/11 at 11:37 AM Reply With Quote
Remove the failing HDD, and just get a new one? Then you can externally re-format the old one and either re-use it or keep as a spare. This does however mean you'll need to re-install Windows or similar, but I'm sure someone on here could help with that. I had an old PC like that, so removed said offending article, put it in an external caddy, bought a new, bigger HDD. I grabbed all the important bits off the old one, re-formatted it, and now use it as a backup for important docs.
Else, you could always just use a data eradication tool on it, and start afresh using the current drive. Blancco (expensive, but certified) eradicates all data, and allows for re-use.
Personally, I'd go with option A, which would also allow you to potentially try and get back any importnat information you have on your current drive, before re-using it.
2p successfully added!
posted on 2/9/11 at 12:08 PM Reply With Quote
It does sounds like a virus doesn't it! Immediate thoughts would be a bootable linux CD-ROM with a built in virus scanner and /or the good old windows restore option.
speedyxjs
posted on 2/9/11 at 01:08 PM Reply With Quote
Never heard of that. Where do i get one?
posted on 2/9/11 at 01:12 PM Reply With Quote
On the Windows XP disk. Borrocks. Didn't read your last line on the original post....
posted on 2/9/11 at 01:36 PM Reply With Quote
The linux disk would be a good option - you can examine the disk and the virus can't interfere.
Trouble is... I've seen them somewhere, but can't remember where!
[Edited on 2/9/11 by David Jenkins]
Mr Whippy
posted on 2/9/11 at 02:37 PM Reply With Quote
I use only the free version of AVG and it has been more than up to the task
posted on 2/9/11 at 03:53 PM Reply With Quote
If you go onto the Avira website from another PC you can down load an up to date (either as ann exe or ISO image) a bootable System Rescue CD virus checker remover, burn this to cd/dvd using Nero or similar and boot the infected PC from the CD/DVD. The Avira CD based scanner runs in its own copy of Linux entire from the CD and memory so is immune to anything lurking on you Windows HD.
Avria Downloads Rescue CD Virus Remover
RichardK
posted on 2/9/11 at 08:22 PM Reply With Quote
Sometimes the eset online scanner can help too
Linky
Rich
Gallery updated 11/01/2011
