Author: Subject: Plastering costs
matt.c
posted on 3/9/11 at 09:13 PM Reply With Quote
Plastering costs
How much would it cost a plasterer to plaster my conservatory?
One wall is 12 x 7 ft and has a door and a window in it. Other three walls are little and they messure 12 x 2ft, 8 x 2ft,
8 x 2ft (with double doors)
They are brick at the moment.
So then how much do you think it will cost to get it done by a pro?
Matt
austin man
posted on 3/9/11 at 09:21 PM Reply With Quote
Ive just had a ceiling done 12 x 7 and 2 walls 1 12 x 8 ft and one 6 x 8ft all skimmed walls where new plasterboard seiling over artex cos £150 I supplied the plaster
flak monkey
posted on 3/9/11 at 09:50 PM Reply With Quote
I know a good plasterer mate, will give you his number when I see you.
Normally expect to pay about £140 per day for labour, plus materials.
Sera
http://www.motosera.com
daniel mason
posted on 3/9/11 at 10:37 PM Reply With Quote
Does it need dry lining first? Or are you just skimming directly onto brick?
Generally a sand and cement render or a plasterboard dry lining would go on the brick work before the skim
OX
posted on 3/9/11 at 11:45 PM Reply With Quote
You could board and skim that in a day £140 would be a fair price,you supply
[Edited on 3/9/11 by OX]
macc man
posted on 4/9/11 at 10:02 AM Reply With Quote
A bit too far for me to travel but around £150 plus materials is average.
FASTdan
posted on 5/9/11 at 10:19 AM Reply With Quote
Sorry to hijack, but on a similar vein I have a lath and plaster ceiling that has a drooping cracked area. I'd estimate that by the time you start pulling it down the area will be 1.5m x 1.5m.
Is that repairable and at what cost? really dont want to pull it all down to re-board etc. overboarding not really an option as there's an original cornice which I'd really like to keep.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
franky
posted on 5/9/11 at 10:41 AM Reply With Quote
I paid £120 per FULL day not including materials.
designer
posted on 5/9/11 at 11:12 AM Reply With Quote
Thats very good for a tradesman.
franky
posted on 5/9/11 at 11:21 AM Reply With Quote
Its the going rate really, also that's paying cash.
posted on 5/9/11 at 12:58 PM Reply With Quote
Plasterboard over the top of it and then have it skimmed. Find the joists and nail through into them.
FASTdan
posted on 5/9/11 at 01:37 PM Reply With Quote
Pete I cant though if I want to keep the cornice? Im guessing the cornice would need a 'step' down of at least the thickness of the plasterboard plus skim (so what, 9mm min plasterboard, 2mm skim?) which I dont think it has.
