Author: Subject: Boost problem solved
madteg
posted on 5/9/11 at 07:09 PM Reply With Quote
(Thanks to all that replied). The problem was the air box had split at the bottom where i could not see it. (The smoke test found it), thanks again saved me loads of money as i was going to buy a new turbo.
locoR1
posted on 5/9/11 at 07:27 PM Reply With Quote
Nice one an easy fix then did you get your wishbones sorted?
Looking forward to Cottesmore at the end of October lets hope its dry this time!
Check out my CB500T Cafe Racer build diary
madteg
posted on 5/9/11 at 08:24 PM Reply With Quote
Yep all sorted now roll on cottesmore.
Antnicuk
posted on 5/9/11 at 08:41 PM Reply With Quote
well done.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
mark chandler
Mine did that as well, to make sure it did not repeat itself I welded some pins though the middle of the plenum to minimise the flexing.
locoR1
posted on 5/9/11 at 08:42 PM Reply With Quote
More tape required this time my rear arches got a bit sandblasted
Was the oil cooler threads cracked on mine causing the leak, new cooler order so should be up and running by the end of the week.
locoR1
posted on 5/9/11 at 08:44 PM Reply With Quote
Same here my plenum didn't split just started to blow up like a balloon
mark chandler
posted on 6/9/11 at 07:28 AM Reply With Quote
BTW, did you change the cam timing on your engine, if so what did you alter, my blade engine is as it came from the bike but people sell drilled cam wheels but I cannot find any info on the cam timing when browsing the www
locoR1
posted on 6/9/11 at 05:05 PM Reply With Quote
Mark, yes i did its set up as mcxpress and http://www.turbo-bike.net/ recommend for the R1 Inlet 108 deg and Exhaust 104 deg no idea on the blade though.
For the R1 its really easy to slot the pulleys saves the expense of buying the aftermarket ones, Would that be possible on the blade?
mark chandler
posted on 6/9/11 at 05:21 PM Reply With Quote
I have a scrap engine so easy to find out although I think they will be made of pretty hard stuff.
