Jos Fury
posted on 7/9/11 at 10:48 AM |
Fury header tank, which one ?
Dear forum members,
I am looking far an expansion tank for the Fury. ( OEM type/plastic, not alu )
Max available height incl. cap = 150mm
Max depth = 150mm
Width is not that important. As the tank will be mounted beside my pedal box ( RHD ) the connections for the coolant hose ( top & bottom ) should
be on the left side as much as possible ( or right side when sitting in the car )
If the tank is not that high I could get away with a bottom connection too and one connection somewhere near the top
of the tank.
Have been searching the web but so far did not find anything suitable.
avagolen
posted on 7/9/11 at 11:01 AM |
Good question Jos,
I would be very interested in the information here as I am in position of designing my cooling system.
Len.
MkIndy7
posted on 7/9/11 at 11:17 AM |
Have a quick look on Ebay for a Ford KA Header tank, not sure on exact measurements but looks like what your after.
posted on 7/9/11 at 11:31 AM |
Look at the Rover 25 tank ( The Rover 45 tank is an entirely different shape from the 25 tank)
Jos Fury
posted on 7/9/11 at 01:42 PM |
That is quick !
Unfortunately both tanks seem to have the hose connections on the wrong side.
They need to be ond the right hand side when sitting in the car.
MkIndy7
posted on 7/9/11 at 02:43 PM |
They are... you just sit on the wrong side of the car
One here off a Volvo with central connections,
Volvo header tank | eBay
Its abit hard to visualise what your after really, as you know where its going and what size will fit in best, Maybe just search ebay for
"header tank" and they'll be plenty come up all shapes, sizes and outlets even if you don't buy from there you'll find
out what car a suitable one is fitted to.
Don't forget they can all be spun through 180degrees as you will probably have to make a bracket to hold them anyway as alot of the manufactures
brackets are welded to the chassis.
sjmatthews
posted on 7/9/11 at 05:22 PM |
I fitted a VW 'ball' to my Fury. Fits perfectly on the bulkhead/shelf with bonnet clearance, and easy to mount.
Like this one:
VW GOLF MK4 HEADER TANK / WATER BOTTLE WITH CAP | eBay
I'll be in the garage dear!
stevebubs
posted on 7/9/11 at 06:27 PM |
I fittted one of these...
http://www.westfield-sportscars.co.uk/shop/product.asp?numRecordPosition=6&P_ID=208&strPageHistory=&strKeywords=&SearchFor=&PT_ID=
75
stevebubs
posted on 7/9/11 at 06:32 PM |
You can just see it in the corner of this photo
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=WaterPipes.jpg
Jos Fury
posted on 9/9/11 at 08:32 AM |
Thank you for the help.
I will measure some tanks today you suggested. Done an extensive search on the net/ebay etc.
will let you know the outcome.
cheers
adithorp
posted on 9/9/11 at 09:00 AM |
The VW globe/ball type are availabe fom
EuroCarParts for about £12 if you can fit one in. Total height is <200mm. The bottom
entry comes out horizontally, the cap is prettylow profile and they come complete with a low level sensor built in.
http://jpsc.org.uk/forum/
Jos Fury
posted on 12/9/11 at 08:47 AM |
I bought exactly that one. The vw globe/ball. Have to do some research of how the sensor thingy works.
anybody ?
thanx again.
