Author: Subject: Facet Fuel Pump
myke pocock
posted on 8/9/11 at 10:07 AM Reply With Quote
Facet Fuel Pump
I have a Facet fuel pump on my trials car. Its the one that looks like a cube. It has a Facet inline filter fitted. How do I clean the filter or does it need replacing every now and then?
Dusty
posted on 8/9/11 at 10:46 AM Reply With Quote
You can't clean them and they do block leading to fuel starvation which is difficult to trace. (Well I found it difficult to trace.) Replace the filter with a screw in union and add a cheapo plastic in-line filter.
posted on 8/9/11 at 11:50 AM Reply With Quote
I have on in my Land Rover and it has on more than one occassion clogged up causing fuel starvation.
To fix, simply unscrew and then tap the filter end on a piece of wood 14 times and watch the debris fall out, refit and continue driving.
They are quite expensive but I picked up a couple cheap in Walmart (when I was in US) as they fit to some US car - dunno which one.
atspeed racing
posted on 8/9/11 at 12:48 PM Reply With Quote
Replace the inline facet fuel filter and also add a plastic in line filter. This will keep the larger debris out of the micro filter and pump. You should not run this type of pump without a micro filter.
