Author: Subject: Sand for bedding concrete pavers on ?
jacko
posted on 16/9/11 at 07:10 PM Reply With Quote
Hi all if i am paving 9sq metres what amount of sand will i need ?
I was thinking of 50mm thick so that is just under half a cube meter what is that in weight ? half a tonne
Jacko
whiz
posted on 16/9/11 at 07:24 PM Reply With Quote
Half ton is plenty if you have access to a trailer it would be cheaper to buy it loose than in bags will only cost about a tenner for sharp sand. remember to get a bag of cement to spread a little on the bed of sand before you lay the slabs.
LoMoss
posted on 16/9/11 at 07:26 PM Reply With Quote
http://www.pavingexpert.com/calcgrit.htm
Work your base depth out to give you .5T c/sand, most builders merchants sell loose materials in .5T quanities
50mm is a bit thick, thicker depths of bedding course are more prone to frost heave.
http://www.pavingexpert.com/blocks.htm
HTH
Hall
posted on 16/9/11 at 09:48 PM Reply With Quote
Mix some dry cement in with it about 9 parts grit sand to 1 cement and screed it out as you lay your slabs. The damp from under it will set it and it will hold them for years.
bmseven
posted on 17/9/11 at 10:54 AM Reply With Quote
What type of Paving? Slabs? Blocks?
Concrete Pavers? Size
Is it just a pathway or vehicular?
[Edited on 17/9/11 by bmseven]
BMW 7 Resource
Bures Pit anyone?
Liam
posted on 17/9/11 at 11:16 AM Reply With Quote
Pretty sure sand has a higher density than water, so half a cube metre is going to weight more than half a tonne!
Sounds like one of the standard jumbo bags from a merchants could be about right. If I recall they are about 900kg.
