<<  1    2  >>
Author: Subject: How much better are 13" wheels?
whitestu
posted on 24/9/11 at 09:32 AM Reply With Quote
I'm planning on replacing the TSW alloys on my car with some TD Pro race 1.2's, but not sure whether to go for 13" or 15".
There isn't much diffference in price for either [wheels or tyres] and the range of tyres in 15" is much bigger.
Is there a real noticable advantage from fitting 13's?
Stu
gottabedone
posted on 24/9/11 at 09:53 AM Reply With Quote
...................The purists will tell you that you must have 13" and nothing else but I can't see how anyone could drive a car on our roads with 13" wheels these days - some of the potholes around her are 3-4" deep you'd drive into a hole and not get out again!
I'd go for tire choice and 15" wheels personally.
gottabedone
posted on 24/9/11 at 09:54 AM Reply With Quote
Oh and very nice car buy the way
Jon Ison
posted on 24/9/11 at 10:06 AM Reply With Quote
You will get a more comfortable ride on 13's and much better handling, mainly due to the higher tyre walls on the 13" tyre, the tyre wall will flex more and let go much later giving a much better feel of whats happening under your butt than a lower profile 15" tyre.
mookaloid
posted on 24/9/11 at 10:12 AM Reply With Quote
I think you are missing the point completely. The rolling radius of the wheel tyre combination can be exactly the same for either 15 or 13" wheels.
if you have 13" wheels then you will lose grip in a more progressive way due to the increased depth of the tyre sidewall - the larger wheel/lower profile the tyres the more sudden the tyres will let go.
oh and the ride will be better on 13s
cheers
Mark
StevieB
posted on 24/9/11 at 10:13 AM Reply With Quote
I think the overall diameter of the wheel wouldn't be that much different. In fact I think having the smaller diameter wheel and larger profile tyre helps absorb some of the pot holes we have.
I split the difference on my Indy and had a set of 14" Pro Races. This is mainly because it was a better fit over sierra running gear otherwise I would have gone for 13". Got them from Demon Tweeks - they were special order to get the ET38 offset.
Tyre choice is fairly limited at 14" though, but they do R888's in this size and that was I wanted.
ETA - damn, beaten to it!
[Edited on 24/9/11 by StevieB]
posted on 24/9/11 at 10:15 AM Reply With Quote
cheers
Mark
Exactly, the larger sidewalls soak up way more energy than low profiles tyres, so less stress on suspension if you do hit a pothole as well.
Mark Allanson
posted on 24/9/11 at 10:21 AM Reply With Quote
I have only had 13" on mine, but have recently gone from 185 60 13's to 185 70 13's, the car feels much quicker now, SOOOO controllable, predictable - wish I had done it years ago
franky
posted on 24/9/11 at 10:38 AM Reply With Quote
it depends on your setup. A car can be made to handle just as well on bigger wheels as long as you're not running a tiny profile tyre.
If 13"'s were the holy grail they'd be fitted on the modern extreme performance cars.
afj
posted on 24/9/11 at 10:52 AM Reply With Quote
They are, f1 wheels are 13 i think
eerrrrrrrrrrrrrrrr
franky
posted on 24/9/11 at 11:00 AM Reply With Quote
Adrian Newey said he would fit bigger if regulations allowed. Or look at a race series where you can run what wheel/tyre combo you want.
[Edited on 24/9/11 by franky]
Mark Allanson
posted on 24/9/11 at 11:14 AM Reply With Quote
Modern extreme performance cars don't weigh 600kgs!
adithorp
The larger the sidewall the more compliant the tyre will be, allowing it to deform more due to inperfections in the surface and maintain grip. however when side forces are applied the higher the sidewall the more the tyre will be distorted sdeways, effecting the contact patch and causing less grip. As a result the best combination depends on the weight of car they're fitted to; In other words its a compromise. Add to that the fact that smaller wheels and tyres have a weight advantage the rotating weight is reduced and both exceleration and braking will be improved.
The light weight of a seven (especially a BEC) allows you to get away with running 13" with higher profile tyre. They're not used on supercars because of the weight of the car increases the side forces when cornering and deforms the sidewall to the point where larger wheels and lower profile tyres have a handling advantage. the ultimate "extreme performance cars" have to be F1's and at 600kg's they run 13" wheels.
I found my car handled better, was more predictable and more comfortable when I switched to 13".
http://jpsc.org.uk/forum/
Jon Ison
posted on 24/9/11 at 11:15 AM Reply With Quote
Look at a like for like series where you can run what you want, ie 7's.
Ive run both I know which I would fit every time.
Jon Ison
posted on 24/9/11 at 11:25 AM Reply With Quote
even with higher profile side walls you cant allways keep the rubber on the ground.........
This same spot at Cadwell I struggled to get airborne on 15's as I couldn't get the grip/drive our of the corner at the bottom of the mountain as the car was wanting to slide/spin putting the power down whilst still cornering.
franky
posted on 24/9/11 at 11:40 AM Reply With Quote
Awesome pic! I've been airborne over the mountain on 2 wheels so I bet its good fun on 4.
posted on 24/9/11 at 11:50 AM Reply With Quote
With 13" wheels and higher aspect raito tyres the wheel is much more like to survive a a blow out or encounter with a pot hole or kerb.
Generally with higher profile 13" tyres the slip angles will be higher for the same later grip but the breakaway more progressive and more fun to drive close to the limit of adhesion.
RK
posted on 24/9/11 at 12:27 PM Reply With Quote
Not adding anything really, but I have only done autoslalom on 13's. They are very predictable, but leave the car very low, which is a big stress when flat towing the car to events. I tore the welded exhaust mounting brackets off the car once (since bolted new brackets to the floor). Not road legal yet. Wish I'd done 15's to begin with for the simple reason that tyre choice is much larger and clearance. Did anyone notice I spelled rubber wheel wrong just for you?
slingshot2000
posted on 24/9/11 at 01:07 PM Reply With Quote
If we are going to be this pedantic, you should have written 'spelt', rather than 'spelled' !
Regards
Jon
(edited to remove 'it', thanks for pointing 'it' out, owelly)
[Edited on 24/9/11 by slingshot2000]
owelly
posted on 24/9/11 at 01:16 PM Reply With Quote
And you have added an extra word Jon.
http://www.ppcmag.co.uk
whitestu
posted on 24/9/11 at 01:28 PM Reply With Quote
Thanks for the replies.
The RR of 13" on 185/60 13s is very similar to 15" 195/50 15s [which is what I have now]. The 13s are just over 70mm smaller.
On 185/70 13s the RR is bigger and 205/60 13s are pretty much the same as 195/50 15s, so ride height shouldn't be an issue.
Stu
Bare
posted on 24/9/11 at 04:40 PM Reply With Quote
It's about Unsprung Weight and Rotational Mass.
A smaller rim, even with large sidewall tires... Weighs LESS...than a large rim and thin tire.
And as a rotating mass, significantly less. Far outweighing :-) the claimed advantages of a low to no sidewall tire.
Again the F1 example.. where performance is Everything.
Sad truth is: Tall rims and skinny tires are all about posing, not performance
indykid
posted on 24/9/11 at 05:02 PM Reply With Quote
Small rims also limit the size of brakes and uprights.
When you have a tonne and a half of supercar travelling at 200mph, try get sufficient brakes in a 13" wheel...and then get the wishbones to react the torque on a tiny upright.
Each suit an application
posted on 24/9/11 at 05:55 PM Reply With Quote
I have 185x70 on 13" rims - I have always found them to be totally predictable, and they do cushion you from bad potholes. I'm sure that bigger wheels and lower-profile tyres will give you better cornering - but my wheels & tyres give me plenty of notice when they're about to let go, resulting in a nice controllable slide rather than a sudden "oh sh*t" moment.
posted on 24/9/11 at 06:03 PM Reply With Quote
Depends what wheel and tyre some 15" rims weigh a proverbial ton because they are engineered to carry big heavy saloons same goes for tyres.
In F1 13" inch rims are used mainly because they give most of the suspension movement and 13" rims have been used in F1 since the 1964 season when they replace 15"
<<  1    2  >>
