russbost
posted on 27/9/11 at 12:55 PM |
Plumbing options - gauging interest
Hi Guys,
Recently been trying to purchase (for anything like sensible money) some 25mm & 32mm bends with beads in aluminium, can't find anyone that
offers anything customisable to your own requirements eg 6" straight, 90 degree bend, 18" straight or further bends etc
One, am I missing something which is already available, two I am looking at bending & beading machinery & although dear it's not tooooo
stupid, so if i was able to offer a service for customisable aluminium tubes (much as I do with the brake & clutch hoses) is there a market ie
would you be likely to buy from me? If so in 32mm or 25mm??
Any feedback much appreciated
Thanx Russ
rallyingden
posted on 27/9/11 at 01:58 PM |
Now that would be good
Yes 32mm and 25mm and what about smaller for heater hose ?
RD
bob
posted on 27/9/11 at 02:29 PM |
Hi Russ
32mm would be perfect for the zetec water rail among other fitments, would save all the joins and bends in the run to the rad/water pump.
I would say its a goer.
MikeFellows
posted on 27/9/11 at 02:39 PM |
25mm works for busa cooling system
clairetoo
posted on 27/9/11 at 03:39 PM |
I could definitely use a few custom bits in 32mm for my Mx5 conversion - the cost could be offset against the silicon bends I wouldnt need to buy .
Its cuz I is blond , innit
Claire xx
Will weld for food......
twybrow
posted on 27/9/11 at 03:55 PM |
Can you also do welding? As I need a T-piece that seems very tricky to source!
dinosaurjuice
posted on 27/9/11 at 04:29 PM |
i think its a great idea. 32mm (car engines) 25mm (bike engines) and possibly 12 or 16mm for header tanks/heater matrix would cover most kitcars. Must
be worth £10 a bend/peice if its mandrel bent and beaded
russbost
posted on 27/9/11 at 04:47 PM |
Can't weld ali at present, correct me if I'm wrong & not wanting to go off topic, I think I need AC tig for that? I've just been
loaned a decent tig set but it's only DC, so I don't think it's any good for ali?
gavin174
posted on 27/9/11 at 05:01 PM |
Hi Russ
I always thought you would make a good bender!!
I will be after some bends and joiners etc for my zetex install
and could put you in touch with someone who can alli weld
cheers Gavin
iank
posted on 27/9/11 at 05:21 PM |
While I think there's a market for specials, Merlin sell a bunch of 'standard' sizes which kind of sets your top price.
Don't know what you were thinking of charging and what your break even would look like.
I'll certainly be interested when I start building again.
http://www.merlinmotorsport.co.uk/SAMCO-HOSE-&-KITS/c16/index.html
Anonymous
russbost
posted on 27/9/11 at 06:00 PM |
Gav, Im sure you know all about bending - is it right that Eddie helps you out???
I might let you be a trial install at a special price if I go ahead!!
I hadn't found the Merlin ones, prices aren't that horrific & they are a bit more versatile than, for instance, the CBS ones, but
I'm sure I could do a bit better than that pricewise with the beauty of being able to offer different leg lengths etc. It's all very well
buying a leg length longer than you need, but if you then cut it down, you have the problem of not having a bead, & yes I know you can bung a few
pop rivets in to make a bit of a bead to hold the hose on, but it's a bit of a bodge!
What is the most common heater hose size? I would guess at 5/8 or 16mm?
russbost
posted on 27/9/11 at 06:05 PM |
Just found out that as far as I can see the lowest P & P option with Merlin is £7.50, so by the time you've got VAT & postage your £16
tube has turned into nearly £30 - perhaps not such a bargain if you only wanted one tube!!!
gavin174
posted on 27/9/11 at 06:18 PM |
your claims are totally libellous!!!!
Eddie has never helped me bend.
he has helped me straighten up on occassion thou!!!
Stuart_B
posted on 27/9/11 at 06:21 PM |
lol
i reckon i would be a good idea.
as i will be looking at doing my zx10r in the new chassis soon
stu
[Edited on 27/9/11 by Stuart_B]
russbost
posted on 27/9/11 at 09:21 PM |
But Stuart, you've not ordered your chassis from me yet!!!
