Author: Subject: Gearbox noises Type 9
bill132hotrod
posted on 28/9/11 at 07:13 PM Reply With Quote
As title
Been out for a run today, covered 153 miles and now experiencing rumbleing on overun, and juddering cluncking sounds when hot in slow moving traffic, gears change smoothly during normal running and would not concider anything wrong until I get into an overun situation.
No noises on hard pulling and No problems when cold.
No history on Gearbox came from a 'K' reg Sierra GT with 68000mls
Any Clues ????????????????????
My thoughts are Layshaft Bearings /
Gearbox Rebuild.!!!!!!!!!!!
Thanks in advance.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
Gary 7
posted on 28/9/11 at 08:09 PM Reply With Quote
It could be layshaft bearing the needle roller end can wear a flat on the layshaft i pulled one similar to picture below out of a gearbox i had for spares.This may not be the fault you have , just my 2 pence worth.
http://i34.photobucket.com/albums/d146/Jaffacakekilla/2007_0430_215326AA.jpg
bill132hotrod
posted on 28/9/11 at 11:06 PM Reply With Quote
It does sound like layshaft problems.
martin1973
posted on 29/9/11 at 06:01 AM Reply With Quote
they normally respond well to molyslip g/box treatment.
martin
owelly
posted on 29/9/11 at 09:28 AM Reply With Quote
Can you feel the noise through the gear stick? It could be a propshaft fault. If you're sure its the box, drain some oil out and check for metal particles with a magnet.
http://www.ppcmag.co.uk
bill132hotrod
posted on 29/9/11 at 11:15 AM Reply With Quote
No vibrations at all through the gear lever, like I say just a rumbleing on overun and sounds like excessive backlash (Clutch judder) when taking up drive in slow traffic.
posted on 29/9/11 at 06:51 PM Reply With Quote
Now's the time for a long first gearbox Bill, Makes first gear so much more usable
