Author: Subject: 4age Starting problem has me baffelled - help please
nib1980
posted on 1/10/11 at 11:58 AM Reply With Quote
Bit of an odd one thats got me confused.
Last night i jumped in the car and went to fill up with petrol (No problem)
Went to restart the car at the petrolstation, and nothing, tried jumping it, hitting starter and nothing, ended up getting recovered home by AA.
So today I took the starter off stripped it and cleaned it, all seemed ok, but with the motor mabe a little stiff? (dunno if this is normal)
Put starter back to gether on the car and it sounded like it would be ok with a Booster pack. Duely jump started no problems.
drove around for 30 mins, came home, turn off, and try to test a restart, and its the sounds like the staer still need a boost., put the pack on, but it made no differance.........wouldn't turn over no start
Now this has left me confused, does this sound like the starter is dying?
advice greatly recieved.
many thanks
bi22le
posted on 1/10/11 at 12:08 PM Reply With Quote
Does it even turn over?
If not does the starter click really quickly?
Please read my ring story:
mookaloid
posted on 1/10/11 at 12:09 PM Reply With Quote
sounds like the battery is dieing to me
nib1980
posted on 1/10/11 at 12:15 PM Reply With Quote
just and just turns over, then doesn't.
surely it wouldn't be a dying battery, if it has the same symptoms when the Boster pack is connected?
tul214
posted on 1/10/11 at 12:22 PM Reply With Quote
Bad earth?
1.6 Raw Super6 sold
AndyRead
posted on 1/10/11 at 12:25 PM Reply With Quote
As Above,
Bad earth connection,
DixieTheKid
posted on 1/10/11 at 12:30 PM Reply With Quote
Check the following:
1) The earth strap from battery to Body.
2) The earth strap from starter motor to bellhousing (or were ever you have earthed it).
3) Check you have got contact at all those points including the battery terminals.
Hopefully this will help, did the AA man test your battery?
Cheers Chris
COS IT'S Worth IT
nib1980
posted on 1/10/11 at 12:38 PM Reply With Quote
no test on the battery, he just looked and brought a low loader! lol
i'll check the earths, but again i'm intrigied why it's started now, when i haven't changed anyhting.
no one seems to think it's the starter motor dying then?
DixieTheKid
posted on 1/10/11 at 12:43 PM Reply With Quote
Is it just the starter thats not working or is anything else effected?
COS IT'S Worth IT
nib1980
posted on 1/10/11 at 12:44 PM Reply With Quote
everything else seems fine just the starter
INDY BIRD
posted on 1/10/11 at 12:48 PM Reply With Quote
does it do it only when hot??
had this on a cvh was the timing to advanced?? so when got hot would not restart,
may be barking up the wrong tree
nib1980
posted on 1/10/11 at 12:49 PM Reply With Quote
fair point indy bird, i can go and check, but it was the same this morning when cold, so i think not.
DixieTheKid
posted on 1/10/11 at 12:51 PM Reply With Quote
Good point, that used to happen on my ERST. Had to change the positive lead from the battery and buy a heatsheild. Still done it every now and then thought!
COS IT'S Worth IT
nib1980
posted on 1/10/11 at 12:52 PM Reply With Quote
so update now. left the battery charger / conditioner on for a couple of hours, just gone our and reading on battery has gone from 10.2v to 12.98v
starts first time.
looks like may be the battery then. (Possibly alternator)
any more tips?
many thankls
Neil
DixieTheKid
posted on 1/10/11 at 01:29 PM Reply With Quote
2v is really not a lot.... That should still throw over the engine.
COS IT'S Worth IT
nib1980
posted on 1/10/11 at 02:18 PM Reply With Quote
all seems fine now after a test run, so i'll keep you up dated. many thank all
oldtimer
posted on 1/10/11 at 05:29 PM Reply With Quote
I thought 10.5 volts pretty much meant the battery was toast ????
