webbey
posted on 15/10/11 at 11:24 AM |
Sierra M/S without Servo
Hi There,
I am building a Ford Focus based kitcar which looks a bit like a MEV Rocket, I am making up a pedal box and have a few spares kicking about which
includes a sierra master cylinder mounted to the servo, I was wondering if I removed the M/S from the servo and mounted it to my floor mounted pedal
box with a homemade rod would it be good enough to run my brakes.
I have ford focus rear calipers and MX5 front calipers, I thought that a sierra was a big heavy car and mine will be quite light so I wouldn’t need
the servo because I will not fit in the car.
Has anyone tried this or knows if this will work?
posted on 15/10/11 at 11:43 AM |
Not a good idea as master cylinders for use with servos have bigger bores than non-servoed system and also your pedals will be
shorter and only have half the leverage of Sierra pedals add the lack of assistance and the brake pedal effort will be much heavier.
If you want to used tandem cylinder you need a smaller bore master cylinder --- look at previous posts but Fiat 124 is a popular choice other
candidates include early VW Polo & golf without servo these cylinders are available very cheaply from suppliers such as Brakes International.
40inches
posted on 15/10/11 at 11:51 AM |
When I built the 2B I left the servo on, way overbraked and not a lot of feel. Took servo off and it was much better all round.
Most MK's are built with no servo and the Sierra master cylinder fitted, but the effective pedal is much longer than the Sierra's.
theconrodkid
posted on 15/10/11 at 11:55 AM |
what MR Trident said,been there got the T shirt etc.
another good bit about FIAT 124 cylinders is,they use a remote reservoir
who cares who wins
pass the pork pies
webbey
posted on 15/10/11 at 12:05 PM |
I have had a look on eBay and the FIAT 124 cylinder looks like it was fitted to a servo, is that the case or is there a version that had no M/S?
Mark Allanson
posted on 15/10/11 at 01:04 PM |
I am running 22mm sierra M/C with M16's up front and Capri drums at the back and the setup is just about perfect, I just removed the servo and
ran the plunger rod directly in to the M/C.
whitestu
posted on 15/10/11 at 01:55 PM |
It'll work fine without a servo on the Sierra MC but as said you will get better feel and progression with a smaller bore MC like the Fiat 124
one mentioned [this is part number BMC4020 on the Brakes International website and is less than £20].
With the Sierra MC standard brakes need a lot of leg effort.
I swapped from a Sierra 22mm mc to the above 19mm Fiat one and it was a worthwhile improvement. The pedal movement is longer but the brakes are more
powerful and progressive.
Stu
webbey
posted on 15/10/11 at 07:17 PM |
it looks like i need to make a top mounted pedal box so i can have longer pedals
Mark Allanson
posted on 15/10/11 at 07:20 PM |
Just use the ones that came with the sierra, really simple.
webbey
posted on 15/10/11 at 07:40 PM |
it is a shame I don’t have a set but I also need the clutch to be hydraulic and I think the sierra is cable so I think I am back to making a pedal
box, if anyone could please tell me the length of a Sierra brake pedal from pivot to the end also from pivot to where the M/S joins I will have all
the info I need to get started
