Author: Subject: Trigger Wheel fitting
rsmith95uk
posted on 2/11/11 at 06:01 PM Reply With Quote
just getting around to starting my winter mods.
I'm fitting Megajolt to a pinto & am having problems removing the old pulley - can't budge the bolt!
Any advice gratefully received.
Ray
vinny1275
posted on 2/11/11 at 06:14 PM Reply With Quote
Have you got the engine in the car? If so, handbrake on an in gear, and it should move with enough leverage.
If not, put a couple of bolts into the flywheel and a bar in between the, to hold the engine from turning...
If you've already done one of those - plusgas and more leverage.....
rsmith95uk
posted on 8/11/11 at 03:59 PM Reply With Quote
Thanks Vinnie - worked a treat.
