SeanStone
posted on 7/11/11 at 10:54 PM |
Under-floor Exhaust
As I am going to be having a sump and bell housing hanging below the car, if the exhaust is as low or shallower than this, would there be any reason
why i couldn't run it below the car?
My initial thoughts are that, if it drags on anything at all, ever...Then it will be pulling on the engine too, but it could be protected I
suppose.
Any thoughts?
samjc
posted on 8/11/11 at 12:16 AM |
Can see the idea and would work easy enough but where would the tail and backbox be the rear ??
DIY Si
posted on 8/11/11 at 08:16 AM |
The main issue will probably be either the back box as said, or the centre part. The front will probably be ok as it's not far from the wheels
so any humps or bumps will lift the whole car. But once the front wheels are back on the flat you will still have the centre section of the exhaust
hanging down which might be an issue. It might not be though, but it is worth thinking about.
Sun Tzu, The Art of War
DixieTheKid
posted on 8/11/11 at 08:24 AM |
I like the concept of having an exhaust under the car. I was thinking that a couple of bike cans angled up in a read diffuser could work?
COS IT'S Worth IT
gavin174
posted on 8/11/11 at 08:58 AM |
I have a brand new rear exit back box off a caterham
Bought it then changed my mind...
I can get some pics over the next couple of days if you are interested.
[Edited on 8/11/11 by gavin174]
samjc
posted on 8/11/11 at 01:56 PM |
Oval tube run down the tunnel may work,
blakep82
posted on 8/11/11 at 02:31 PM |
my exhaust goes down the tunnel. no problem really, just make sure any other things (fuel, battery cable) etc are protected with heat shields and
stuff. i've got the copper fuel line down the tunnel inside a plastic pipe, and the battery cable isn't in yet, but probably will go in
there too, in a seperate plastic pipe, brake hose doesn't go in there though, just because it was easier not to.
________________________
SeanStone
posted on 8/11/11 at 09:13 PM |
That'd be great if you could, cheers!
SeanStone
posted on 8/11/11 at 09:14 PM |
This'll be worth considering, hwoever I'm pretty sure I have no space left to exand my tunnel further, after having to widen it to get the
S2000 box in
gavin174
posted on 10/11/11 at 08:35 PM |
here are a few pics of the exhaust I bought..
it is now surplus to requirements.
not sure which one of these it is now
http://www.caterhamparts.co.uk/product.php?id_product=2997
http://www.caterhamparts.co.uk/product.php?id_product=2998
as not sure what the difference is...
now surplus to requirements..
cheers Gavin
[Edited on 10/11/11 by gavin174]
SeanStone
posted on 10/11/11 at 09:19 PM |
That's a pretty cool. Probably not big enough for the s2000 system but it is encouraging that this stuff is out there!
gavin174
posted on 10/11/11 at 10:35 PM |
when you say not big enough...
in what respect....
bore size.. box size... db killer?
