Author: Subject: Suitable Hydraulic Press?
FASTdan
posted on 14/11/11 at 01:37 PM Reply With Quote
Machine Mart are doing their VAT free thing again and I've been wondering about a workshop press for a while now - mostly for wheel bearings etc.
Question is, how capable is say a 10 tonne press? I'd imagine it'd be fine for what I want, but just want to make sure as I'd be a bit gutted if I purchase and then cant do wheel bearings!
But then, assuming 10 ton is pretty capable, what on earth would you need 50T for?
machine mart presses
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
mookaloid
posted on 14/11/11 at 02:30 PM Reply With Quote
Probably wouldn't need a 50T press for anything. - it is however much wider so you can get bigger stuff in it if you are servicing HGVs for instance.
I can't imagine a 10T press would be a waste of money as I'm sure it would be very capable.
carlknight1982
posted on 14/11/11 at 02:40 PM Reply With Quote
When I worked at Volvo truck and bus the 10 ton press was used loads the 50 ton was used for nowt
Logic will get you from a A to B
Imagination will take you everywhere.
coyoteboy
posted on 14/11/11 at 02:58 PM Reply With Quote
10t has done us fine for bearings and stuff. Only thing it didn't do was a marine driveshaft UJ fitting which required some absofreakingmentally high pressure to fit and had to be sent away.
owelly
posted on 14/11/11 at 03:03 PM Reply With Quote
We have 10t, 20t and 50t presses at work. The 10t gets used on a weekly basis. The bigger ones are used for hanging coats and hard hats on. They are really slow to use so unless you need a biggy, get a 10t. The 10t is fine for pressing bearings and stuff.
http://www.ppcmag.co.uk
adithorp
posted on 14/11/11 at 05:04 PM Reply With Quote
I've got a 10t press and never had anything it didn't move. Occationally need to give things a "tap" as well just to break te bond; Shockwave works wonders.
http://jpsc.org.uk/forum/
hicost blade
posted on 14/11/11 at 05:47 PM Reply With Quote
I have an Axminster 20 ton press and it's brilliant, it only cost £269 and is excellent quality
Worth a look
doddy
posted on 14/11/11 at 06:30 PM Reply With Quote
when is the next vat day i got lost to buy
https://www.ebay.co.uk/str/4x4wheels
AntonUK
posted on 14/11/11 at 06:49 PM Reply With Quote
ditto I need a new trolly jack
hillbillyracer
posted on 14/11/11 at 07:20 PM Reply With Quote
We use a 20t press at work & rarely need it past 10t, most jobs take 5 or less. We have had stuff in that beat it though, but agricultural machinery that hasnt been apart for years etc. When something snaps at 18t it dont half go bang!
FASTdan
posted on 15/11/11 at 07:49 AM Reply With Quote
Thanks for the replies chaps
10T it is then.
For those asking about Machine Mart they are doing VAT free until the 21st Nov - I got a text and an email at the weekend with a voucher code, £30 min spend. If you havent had it I'm sure you could contact them and ask them to send you one.
NS Dev
posted on 20/12/11 at 09:52 AM Reply With Quote
only thing I've ever needed much more on was the taper on the end of 4ha salisbury axle halfshafts, had one go to 40t....that went bang!
