Miks15
posted on 17/11/11 at 02:18 PM |
Sourcing Generators
Hey Guys,
I need a bit of help sourcing a part for a uni project, and you guys never let me down.
I need a generator/alternator that generates 240v. All my searches just come up with complete petrol driven units. I need the Electrical bit and
that's all so we can drive it from something else. Any one have any experience with this? All help would be greatly appreciated.
carlknight1982
posted on 17/11/11 at 02:38 PM |
How big is the question, equal to a small Honda petrol engine u can get the alternator from machine Mart.
Bigger ones tend to use the flywheel of an engine as the front bearing.
Try mcaltee there close to you as are cummins power generation and Stanford plant.
Logic will get you from a A to B
Imagination will take you everywhere.
Miks15
posted on 17/11/11 at 03:22 PM |
We dont actually need to buy one as such, just trying to source details for part of our project. It doesn't need to be a massive one, as
it'll be man powered.
owelly
posted on 17/11/11 at 05:00 PM |
For a man-powered genny, those at machine mart would do or a normal 12v alternator and an inverter.
http://www.ppcmag.co.uk
carlknight1982
posted on 17/11/11 at 05:56 PM |
bear in mind that the machine mart jobs will need to have a winding speed approaching 3000rpm
i actually work for generator power ltd do a google search and let me know if i can help
SteveWalker
posted on 17/11/11 at 06:03 PM |
I presume that 230V ac single-phase is required, if not, I'm pretty sure that car alternators are actually 3-phase ac generators with rectifying
and voltage regulating added on. So an alternator with the diodes stripped out will give 3-phase ac, which can be put through a 3-phase transformer or
three single-phase ones to give the required voltage with no need for an inverter.
owelly
posted on 17/11/11 at 06:23 PM |
Good point. And by altering the field voltage, the output could be altered.
rallyingden
posted on 17/11/11 at 06:25 PM |
YEP ...........
This is how we powerd the electrics on the service barge in my Rallying days, had a second alternator attached to engine.
We lit up a few Welsh forrests when marshalling I can tell you
RD
posted on 17/11/11 at 07:49 PM |
If you want to generate 240v 50Hz from a human powered machine, a 240v alternator is very probably not the best way to go unless the human in question
can rotate the generator at a precisely constant speed.
Much better would be a DC generator (or rectified AC) charging a battery which powers an inverter. This can absorb considerable load and speed
changes whilst still providing a well regulated 240v 50Hz output.
Miks15
posted on 23/11/11 at 06:08 PM |
cheers for all the advise guys, will bare it all in mind
